Question about Hotpoint HSS25GFP Side by Side Refrigerator
How do you turn off the water line to the refridgerator? Is there a shut off on the fridge somewhere? Our water is going to be shut off on tuesday for work in the area and then will be back on with a boil water advisory. we don't want cubes to made with this water or have it contaminate the water in the fridge.
  • 443 Answers
There is not a shut off valve on the refrigerator for water supply, but you should have a valve on the water supply line behind the refrigerator or at the water supply line where it taps into the main waterline, I would shut it off and then when the water supply is returned to service, I would disconnect the water line from the back of the refer and purge the water line for about a minute or two into a bucket or equivalant, just to make sure all sediment and other foreign stuff doesn't contaminate your refer.
Good Luck !
Posted on May 02, 2010
253.63712300 sears Hoffman estate fridge has small pools off water that sometimes freeze on back of fridge shelf. Sometimes small trickle of water leaks onto floor. the refridgerator and freezer are s
probably dust, hair, lint plugging the drains.
you have pets?
have it serviced by a professional, or you can disassemble all the drain lines and conduit and pans and clean yourself. good luck
call a PROFESSIONAL
Dec 29, 2014 | Estate Refrigerators
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
Saddle valve on water line to refridgerator won't shut water off
If you can not shut the valve off then most likely it has calcium build up in it. I would recommend shutting off the water supply at the angle stop. Then removing the saddle valve and see what is going on. If it is built up with calcium you may be able to clean it depending on how shot it is. If you are unable to clean it then a new one is not that expensive and they are easy enough to replace
Jun 05, 2010 | KitchenAid (KSRD22FKST) Side by Side...
WATER NOT WORKING
Yes there is a shut off valve located usually under the sink or where ever it is getting its water supply, there is also the angle stops that you shut off that keeps water from going into the lines. check both of those, if there is still a issue, then it is something to do with the fridge. Something has got knocked loose and will need to be fixed
Jun 01, 2010 | Kenmore 64802 Top Freezer Refrigerator
How to replace an icemaker hose
Turn water off from the supply. There should be a valve that the 1/4" water line connects to, if not you will have to shut off the water main. Using a wrench remove the nut from the water line connection (usually a compression fitting. You will need a need compression sleeve with the new line x2, one for the valve and one for the fridge. Next disconnect the line from the back of the fridge. Run the new line the same way the old one was run, for easiness. Make sure you leave enough slack behind the refridgerator to allow it to be pulled out and cleaned behind. Once all connections are tight you can turn the water back on and ensure you don't have any leaks. Hope this helps.
Mar 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
GE Refridgerator leaking
it is possibe the inlet to the drain line may be plugged.The defrost water cannot run down the drain line to the pan on on the bottom.Also make sure it is level
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water coming from somewhere inside my fridge
this is because your defrost drain tube at the funnel inside your fridge is clog your fridge defrost every 6 to 8 hours the water has to drain in a pan under te frige open the fridge door you will see above a small funell typy plastic tubing going tru the wass pull it out and clean every thing should be fine thanks from gilles
Mar 13, 2009 | Refrigerators
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
207 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
