Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Trimmer not getting gas
Weed eater fl26. wont start. not getting gas. if i pour gas directly into air filter it starts for a second
  • 64 Answers
Carburetor diaphrams are stuck. clean the carb and check the diaphrams to see if they are stiff.
Posted on May 04, 2010
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Air filter replacement weed eater
on your weed eater there should be a lil bubble looking thing called the primer somewhere around tht should be a black box with a screw of some sort on it take the lid to the black box of and theres your air filter
Aug 17, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
My weed eater trimmer gas lines disintegrated. I've replaced them and the filter but the trimmer still won't start. What might be the problem?
There might still be air bubbles trapped in the new gas line. First make sure that is enough gas in the tank. Try pumping the dome shaped transparent rubber to get the air out and let the gas in. Try starting again.
Hope this helps!
Fix14
Jun 16, 2010 | Poulan Garden
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Trot Bilt 4 cycle weed eater catches, but wont run.
rebuild carb to fix problem.let me know if this help you.ok
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
My te 475 weed eater wont start
Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
618 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
