Question about Yamaha HTR-5850 Receiver
How do i connect my ipod to a Denon receiver? The receiver has a left & right audio input jacks under v aux input
    Problem Solver:
  • 6 Answers
De los cables macho- hembra tienen una entrada como de audifonos y las salidas en modo RCA blanco y rojo con 2 entradas conectalas en cualquier entrad posterior de tu ampli ya sea cd o en alguna auxiliar que diga play ok. saludos
Posted on May 02, 2010
I have a Denon 485s. Can I connect my Ipod to it?
Yes, you can. You will need a cable like this
http://www.amazon.com/gp/product/B00004Z5CP/ref=pd_lpo_k2_dp_sr_1
that you will plug in the headphones socket on the Ipod and the Line In Audio connections at the back of the Denon.
Jun 13, 2011 | Televison & Video
I have a denon ipod dock and a harman/kardon receiver. Can I connect the dock to the receiver?
To plug the dock into the receiver to supply power and interface with the iPod you would have to have one with a built in iPod. Most receivers will not do that, the most common way to connect an iPod to a receiver is using a 3.5mm to RCA cable. You don't even need the dock to do this, you can plug the iPod directly in. You can find this cable at most electronics shops if you don't want to buy online, like Best Buy or Radioshack.
Make sure you connect the white and the red end of the RCA cable to the correct sockets on your receiver, and the small 3.5mm jack into the iPod or the iPod dock, you have to turn the iPod volume up and select the corresponding input on your receiver. If you plugged the 2 RCA jacks (white & red) into the socket labeled "AUX" or "Video 1" you have to select "AUX" or "Video 1" in order to hear the sound.
Jun 18, 2010 | Harman Kardon Audio Players & Recorders
Configuring the Aux Input terminals to play my Ipod Nano
Hello
You need a cable which goes from RCA to mini jack. The mini jack goes into your ipod and the RCA cable goes into the back of the amp under input heading. Then you just need to set the amp on input via remote or manual and you should be set. Please rate this.
Best regards
Sep 28, 2009 | Denon AVR-2307 Receiver
I have a Denon AVR-1500 Reciever and I would like to connect my iPod to see if I can drive my home speakers from my iPod, the aux jacks and other choices of input jacks do not seem to accept the formatted...
How are you trying to connect your ipod to the Denon? i.e. What connector, or cables are you trying to use?
If nothing else work, you could try and use the headphone output of the ipod to connect to your receiver. ( Cable required would be stere pin to RCA stereo out). The volume control of the ipod will then become the gain control.
Mar 08, 2009 | Denon AVR-1082 Receiver
Hooking up an external audio source (IPOD) to the Denon AVR 3803
Yes it is.  You will need to pick up a mini plug to stereo rca adapter.
Jan 07, 2009 | Denon AVR-3803 Receiver
Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Nov 26, 2008 | Denon AVR-1603 Receiver
Trying to sort aux-in
as you do not mention the model I have to guess that your player has a aux-in on phono (or RCA) jack. If you want to plug the iPod just buy a "Twin phono to 3.5mm stereo jack cable".
You can find in many superstores or Maplin.
Mar 30, 2008 | Audio Players & Recorders
Hooking up ipod
THe easiest way to hook an iPod or any other personal audio player to almost any audio receiver is to pick up a cable having a stereo miniplug (like the plug on your earbuds) on one end, and two RCA plugs on the other end. You should be able to get this cable from almost any electronics or discount store for under $10. The miniplug goes in the iPod's earphone jack, and the RCA plugs connect to an unused input on your receiver. Inputs marked "AUX" or "CD" are a good choice, or even a "TAPE" input. Set the iPod to about 3/4ths volume and adjust the receivers controls for desired volume.
Feb 14, 2008 | Denon AVR-485 Receiver
Computer to Denon via Monster Headphone cable to V.Aux (Front) RCA inputs
Are you using a stereo-mini to RCA cable that has a red and a white RCA plug? What I mean is, you should have the one cable coming out of the headphone jack on the computer, and two (left and right) cables going to the receiver. The only other thing I can suggest is making sure the cables are tight. Maybe try another input on the receiver. There really shouldn't be any feedback unless there is some underlying problem.
Jan 08, 2008 | Denon AVR-3806 Receiver
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Yamaha HTR-5850 Receiver Logo
174 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
