Question about Samsung SGH-E900 Cellular Phone
When i slide it up the screen is not respond. it is not damaged. because sometimes is work as it supposed to do.
    Problem Solver:
  • 11 Answers
Your sliding ribbon (in hindi called patta) may be changed . after sliding up or down it displays or in a blank position
Posted on May 02, 2010
Swipe wont open phone
It seems that the digitizer is not working properly, if you bought new i suggest you return it.
Apr 18, 2014 | Samsung SPH-L720 Galaxy S4 16GB Sprint...
Water damage and the screen is not responding
The phone may still be damp inside. Try using a blow dryer to finish drying up the moisture in your phone.
Jan 10, 2013 | Sony Ericsson Xperia Play R800i Unlocked...
2003 Dodge caravan sport. First, the passenger sliding door lock was not responding to lock and unlock. Only intermittantly. Now, the driver sliding door is copying it. Sometimes, only one does it, th
No, not so strange. - Happens a LOT. Sometimes you can get them working again by cleaning the electrical contacts that are on the front edge of the door and their mating contacts on the "B" pillar area. If cleaning the contacts does not get them working again, then you most likely need to replace the door lock actuators inside the doors.
Apr 19, 2012 | Dodge Caravan Cars & Trucks
My Samsung SGH-a877 touch screen does not respond to "touch" nor "tapping". The touch screen has always been flakey. Now the screen is totally dead. The slide out keyboard &...
Usually when touch screens don't work, it is due to water damage. You can bring your phone to your carrier's nearest store and ask someone that works there to check if your phone suffered water damage. They'll check the inside of your phone. If that's the case, you'll probably have to buy a new one. If you're insured this shouldnt be TOO expensive. But if you bring it to the store and it's NOT water damage (perhaps a software issue), they should replace the phone for free!
Hope this helped
Please rate my solution!
- Frankie
May 02, 2011 | Samsung SGH-A877 Impression Cell Phone
While i was typing an s.m.s,the touch screen suddenly stopped responding.
HI,it depends on the phone you are using if it's a flex phone (slide phone or a phone that has not slide.
Slide phones,
The reason your phones touch screen is not working is simply because there is a problem with the flex of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flex of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flex that runs through the screen to the panel, carefully detach the flex from the panel,
9. unscrew the screen of the phone, remove the flex connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Not a slide phone,
You will have to replace the touch screen with another one for it to function properly again.
Take care .
Aug 22, 2010 | Cell Phones
Screen not responding following extended period of storage...
The digitizer is very thin and paired with the screen. Sometimes they can get so pressed together with time and storage that can cause it to fail. Some people believe that you can put a spacer in there to separate them and try to "unstick it". This involves taking your screen apart and it might not even fix your issue. I would look on eBay or other sources for a replacement screen and just replace the whole thing personally.
Aug 21, 2009 | Palm m505 Handheld
The screen won't respond
format your phone and reinstall the os once again...
this will sort the problem
all the best
Nov 20, 2007 | i-mate Pocket PC
Samsung D-840...black screen...red button not functioning
The same thing has happened to my D840. Very annoying as ive only had it 5 months. After a bit of research and asking around, ive found out that this is a very common fault with these phones. The ribbon inside which connects the screen to the main body of the phone is damaged due to sliding the phone open and closed. Surely they should sort this problem out if the main feature of the phone is to slide it open. Crap.
Nov 12, 2007 | Samsung D840 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
