My SSD drive isn't detected in Windows, I entered the bios and added to the list of hard drives, but when I click on My Computer, it isn't there despite being in the device manager.
  • thejzone May 02, 2010
    I have a Intel X25-v Sata Solid State Drive,
    and I am using Windows 7.
    The tool that intel provides says the drive needs to be partitioned, something which I do not know how to do.
    Okay I did it! well you did.
    Thank you very much!
  • 493 Answers
If you install wrong device driver or not compatible driver, it may cause such problems.
- Uninstall the current drive from windows.
- Install the original drive give with CD. If the installed (given) driver is not compatible with your operating system you should find the right device driver fo your windows operatig system's version.
- Then restart the computer.
What is your SDD name and model?
What is your operating system? (Windows XP, Windows 7, Vista etc.)
Waiting your comments.
Hope this helps.
Posted on May 02, 2010
  • Ibrahim OKTAY
    Ibrahim OKTAY May 02, 2010
    Hi again,
    Yes, you should format it for the first use.
    To format the SSD drive do followings: ( Do not make mistake while writing the commands because you may format your hard drive by mistake !!! Be careful.)
    1. From the start menu write "command prompt" and enter to open the command prompt.
    A black small window opens. See picture below:
    2. In that command prompt, Type:
    cd c:\windows\system32
    3. Type:
    diskpart.exe
    4. Type:
    List Disk
    to determine the name of your SSD.
    5. Type:
    Select Disk #
    where #Disk Number# is the name of your SSD.
    6. Type:
    Create partition primary align=4
    7. Type:
    Assign Letter=E
    to assign this new partition the letter E.
    8. Type:
    Exit
    9. In windows, click start, right-click My Computer, and select Manage.
    10. Click Disk Management.
    11. Right click the SSD partition (E), and select Format.
    12. Name the partition according to what kind of drives you are using, and format the drives as NTFS.
    After the commands you will press the enter as you know in the command prompt.
    Hope this helps.
    Be careful not to select wrong disk to format.
    First read all the writtens and ask me if you have any question before begin formatting.
    Hope this helps.
SNV425S2128gb
The driver should be built into the OS. If you can't access the SSD from Windows Explorer, you may need to format the drive or it is a failed unit. If you have connected the drive to a SATA port on your motherboard, you should check if the drive shows up in your BIOS (assuming good cables and power). Next go to the Disk Management tool with an administrative user account. (Click Start > Control Panel > System and Security > System > Administrative Tools. Then go to Computer Management and the Disk Management tool. Alternatively, choose the Command Prompt (under Accessories) with a right click and select Run As Administrator. Then type in diskmgmt.msc and press Enter.) Check if the drive is listed there. It will be disk 1, if you have the usual single hard drive. If it has unallocated space, you can format the drive and give it a letter name here.
If you don't have the drive listed here, try different power cables from your power supply and SATA cables. If it still doesn't respond, RMA the drive if it is under warranty.
I hope this helps.
May 03, 2014 | Kingston Ssdnow Snv425S2128gb 128 Gb...
P2120 does not recognize SSD
Did your SSD come with a driver CD? If so, install the driver on your LifeBook. If you do not have a driver, go to Computer => System => Device Manager, right click on the drive and select "Update Drive Software". If the drive is not in the list, and the drive is a USB drive, then go into the BIOS setup (typically press F2 on powerup) and enable USB drives.
Nov 16, 2013 | Fujitsu LifeBook P2120 Laptop DC Car...
Operating system not found
I have run into this problem before after just changing out my RAM and adding another HHD for more storage I had to just simply reload my Windows 7 64 bit OS. after a reboot, no more problems.
Jul 12, 2013 | ASUS Computers & Internet
Dell Inspiron 6400 won't detect SSD Drive
I think you were on the right track, the Dell Forums, if they have done it successfully , ask they how. I would only be covering ground you have already covered.
May 17, 2013 | Dell Inspiron Computers & Internet
My dard disc wont detict
When installing a new hard drive, a PC may not recognize the hard drive. Incorrect cable installations, jumper settings and BIOS settings may cause the computer to be unable to detect your hard drive. Due to the vast differences in hard drive types (IDE versus SATA) and brands, motherboard brands and types, and BIOS types and configurations, please download or acquire your motherboard and hard drive manufacturers' documentation prior to acquiring a hard drive. Make sure that the type of hard drive you plan to purchase is compatible with the motherboard.
Shut down the computer. Unplug all cables and peripheral devices. Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist. Remove the computer's side panel. (Cases vary. Some will require a small Phillips screwdriver for removal and others feature screwless designs. Please see your case manual if you are unsure.) Locate the newly installed hard drive. Check that two cables are running from the hard drive to the motherboard and to the power supply. If you see only one cable or if either of the cables are not securely seated, plug in the appropriate connector(s). Leave the case's side panel off for now. Reconnect the power cable, monitor cable, and keyboard and mouse connections. Restart the computer. Enter your BIOS immediately. (Your BIOS usually alerts you to the key required to adjust settings. If your screen does not show this information or if you are unsure, consult your motherboard manual.) If it is an IDE hard drive, enter the IDE settings. The BIOS should show the hard drive. Configure it as primary or secondary, according to your computer's configuration. (If you have only one drive, set this to primary. Otherwise, set as secondary.) Save your settings, and exit the BIOS. Once you are certain that the the PC is recognizing the hard drive, replace the side panel. Detect a SATA Hard Disk If you have connected a SATA (serial ATA) hard drive to your computer but are not able to access the files on it, then your system may not be detecting the drive correctly. On either a PC or Mac computer, you can manually detect and mount a hard drive that is locally connected. Once properly detected, the drive will become available for file transfer.
Plug the SATA hard drive firmly into your PC computer and ensure that the drive is powered on. Open the Start menu and click on the "Control Panel" icon. Open the "Administrative Tools" folder and double-click on the "Computer Management" icon. Go to the "Disk Management" tool on the left side of the control panel window. This brings up a list of all drives currently connected to your computer. Right-click on the SATA drive that you want your computer to detect and choose "Change Drive Letter and Paths." Click on the "Add" button and then select the drive letter that you want to be assigned to the SATA hard drive. Click "OK" to save the settings and detect the SATA drive. b> Mac Instructions b> Plug the SATA hard drive firmly into your Mac computer and ensure that the drive is powered on. Open a new Finder window and navigate to the "Utilities" folder, which is located in the "Applications" section of the Mac hard drive. Double-click on the "Disk Utility" icon. Highlight the SATA hard drive that you want your computer to detect from the list of connected drives on the left side of the window. Click on the "Mount" button at the top of the window to have the system manually detect the SATA drive. Hope this helps.
Dec 29, 2012 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
Ssd won't show up as destination drive.
I'm not sure this is your problem, as you question isn't descriptive enough. But here's a solution if I do understand your question correctly.
When I have installed new hard drives in the past, I did the physical install, turned the computer on, and they just worked. Not so with SSDs I've installed. After the physical install, the SSD does not show up in the "Computer" window with all the other drives; because it's not FORMATTED.
Solution:
Navigate through:
Start > right-click on "Computer" in the right pane > select "Manage" > in the left pane select "Disk Management"
All the drives will show up in the main window, including the SSD you just installed. If it does not show up, there's a problem. Maybe one of the cables isn't fully inserted, or there's a defective cable, or a defective SSD.
You can tell the SSD from the other drives by the Gigabyte capacity, and also by the fact that it does not have an assigned drive letter (e.g. C:). Also, it's named something like "New Edition".
To continue to formatting, navigate:
Right click the SSD > select "Format" > select "Quick Format"
A drive letter will be assigned. You are given the option to change this letter if you want. Also, you are given the option to name this drive. This name will appear with the drive listing in the "Computer" window. I simply used the name "SSD", however if you want something more discriptive or colorful, it's your computer, it's your SSD, you can name whatever you want.
The other format option is for when one is installing a used HD which may have bad sectors. That option scans for bad sectors, and takes a LOT longer to format. Not necessary for a new SSD. Plus, you can scan a drive for bad sectors anytime with the "chkdsk" command.
The SSD is now ready for use, including for use as the main drive. Windows will happily load onto this drive.
Nov 10, 2012 | Samsung 830-series Mz-7pc128n/am 128gb 2.5...
Hard Drive media Problem :S
Presumably, you have an "internal" hard-drive that the BIOS is detecting.
If it is the _only_ disk-drive in your computer, remove it,
and temporarily connect it as a "slave" drive in some other computer.
Then:
Click: Start
Click: Control Panel
Click: Classic View
Click: Administrative Tools
Click: Computer Management
Click: Storage
Click: Disk Management (Local)
Does the drive show there? Is it listed as "Healthy" ?
Does it have a drive-letter assigned?
Sep 16, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Hard drive not found
When is your hard drive not recognized?
At boot or in the BIOS?
You might haven connected your hard drive correctly or you'll need to enter bios and select an option for bios to detect your hard drives and save the new configuration.... otherwise there is a serious problem with your hard drive not functioning.
At windows XP?
You might need to enter windows ADMINISTRATIVE TOOLS in the CONTROL PANEL and click in COMPUTER MANAGEMENT in there click STORAGE/DISK MANAGEMENT you'll see all your connected hard drives, your new hard drive should be listed there, but may not have a letter assigned/partitioned or formatted. Do so and it will be recognized.
If you're trying to install windows XP?
It's probably because your PC has the new SATA interface hard drives, you need to load a special SATA driver through floppy disk during at the beginning of windows XP setup, for it to find hard drives on your pc. You need to make this floppy disk with files that are available on your motherboard CD, in there are all the instructions you need.
Jan 07, 2009 | ASUS M2A-VM (0610839149438) Motherboard
How to load new ssd for eee pc
By SSD I assume you are refering to a Solid State Drive to replace your existing hard drive. If this is the case you need to install the drive and then boot off the CD that came with your computer and reinstall the operating system. Note that all you old info will still be on the original hard drive but you can still access it by purchasing a 2.5 inch USB hard drive enclosure. When you plug it into a USB port it will be detected as a second hard drive.
Jan 02, 2009 | ASUS Eee 900 Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
