Question about Jenn-Air Refrigerators
Ice maker stopped working in freezer. Upper part of side by side freezer not cold enough. Lower part of freezer frost on back wall of freezer compartment. Temp set at middle. Refrigerator now not cold enough temperature above medium? Not cold enough food starting to spoil. Doors are both sealed properly condenser motor running continually.
  • shealong2 May 02, 2010
    Coils frosted over on freezer side although fan motor still working it appears to be reason freezer side and refrigerator side not working properly. Removed panels on freezer side turned freezer temperature to off position for defrosting. Left freezer door open. Will let completely defrost then turn back on to see if this was the problem. If coils just frost over again what would be the next step?
    President:
  • 2,923 Answers
Based on your statement, ice maker stopped working, freezer is not cold enough, frost on the back wall of freezer compartment.
You can begin checking the defrost timer. Test this by manually advancing to the defrost cycle. You can usually manually advance this timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8′s of a turn. The timer should advance out of the defrost cycle in less than an hour.
To test if the cold control is bad, you can temporarily jump the two wires at the cold control. If this jumping gets power to the compressor, the cold control needs to be replaced.
If there is a break in the wiring, your freezer will not work. Testing wiring is a long, tedious process. You need to check each wire with a meter to see if there is continuity. If there is, the wire is fine.
See if the compressor motor is running. The compressor is at the back of the freezer near the bottom. If it’s humming, or making a steady noise, and your freezer is still not cooling properly, there could be a problem with one or more various components. If it is running, but your freezer is still not cooling at all, there may be a problem with the condenser or evaporator coils.
Sometimes you can hear a click-buzz-click sound coming from the compressor. This is the relay/overload at work. If you hear this, power is getting to the compressor. If you do, something is wrong with either the compressor or the compressor starting components. If you have a newer model with solid-state starting components, you may not hear anything at all.
The worst thing that I could think of is, there could be a leak in your refrigerator and refrigerant or freon level is low, and you will need to contact a professional appliance repair person.
Thank you and good luck!
Posted on May 02, 2010
    Genius:
  • 1,416 Answers
In a situation like this were two door side of refrigerator are not function properly as it is expected to or one out of the two fail
the problem is always from what will call dryer if the compressor is work in fine it transfer gas and oil from the compression down to the condenser for freezing and cooling and then return it back when the system is switch off
what you need to do to fix up the problem first is that heat the dryer with a tea spoon dust or remove the dirty blocking the oil and gas form proper flow
you can identified this dryer at the back or side of your freezer depending on were it located it is black in colour and some times in brawn it look like a marchine gun bullet
then if this fail you will have to change the dryer and real run gas back to the compressor
thank you, and thank you for using fixya .
My fridge ( above model) stopped making ice and is not making things cold on fridge part. put in a new filter thinking they were related but problem continues. Please Help.
if it has stopped cooling effectively in the refrig. most likely the freezer will fail in the next few days... the ice maker operates not only off of mechanical gears ,and water but also has to be cold enough in freezer to harvest ice... you need to check the freezer back wall and make sure there is no frost build up on back wall.. if there is then you have a defrost issue and need to address it quickly.. you will have to remove back wall along with shelves in the freezer section..take a hair dryer and thaw out ..check the heater for any breaks using a meter with continuity on both ends.. also check the drefrost terminator it is located on the coil usually top left or right side. if all looks good will be defrost control ...hope this helps repost with anymore questions....good luck to you....
Jan 09, 2011 | Frigidaire FRS3R5EMB Side by Side...
Freezer does not get cold enough to freeze so ice maker does not work
Check for frost on back wall of freezer if there is frost you have a defrost problem
Feb 17, 2010 | GE GSS20IEP Side by Side Refrigerator
Ge side by side is getting a pile of ice on freezer floor
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Dec 12, 2009 | Refrigerators
FRIGIDAIRE frost free refrigerator seems to be leaking. Items in freezer are frozen...items in refrigerator are cold...any ideas? It has an ice maker which is working. Approx. 13 years old.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 28, 2009 | Refrigerators
Ice maker is not making ice and water leaks from bottom.
Ice Maker
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 21, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker quit working
Sep 07, 2009 | Refrigerators
The freezer has water and ice leaking in the
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrig not cold enough, ice buildup on banck panel of freezer
ice build up means your refrigerator is not going through defrost cycle. you have ice build up on evaporator which restricts your cold air flow into the fresh food side. check defrost timer, defrost thermostat located on evaporator behind the wall where your getting frost. check defrost heater. it wraps under the evap.
Jun 21, 2009 | GE Refrigerators
The freezer is cold but not cold enough to make ice
Check the back (interior) lower half of the freezer wall. If you see a frost build up, you either have an issue with your defrost cicuit (timer, heater, thermostat) or the evaporator (freezer) fan is not running. If there is not a frost build up on the back wall you either have a sealed system (weak compressor, leak or restriction) problem....or the condensor fan motor is not working. This would cause the compressor to overheat and shut down until cooled, and prevent the deep freeze.
Jun 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
22 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
