Question about Panasonic NN-P794SF Microwave Oven
I want to change the light in my microwave. Panasonic nn-p704sw. I took apart the covr and foung the light attached to a plastic scockrt. I tried to unscrew but the bulb was tight. should i apply more pressure or does the bulb and socket come in as one unit?
    Problem Solver:
  • 6 Answers
Typically the bulb will unscrew from the socket. If you can remove the bulb and socket with the wire from the microwave (wire hanging from the microwave) you might be able to get more pressure on the bulb to turn it. Keep in mind that the bulb may have been in the oven for several years and there may be a build of grease on the treads of the bulb so it could be really stuck. Put a cloth towel around the bulb and wear gloves so you don't cut your hand if the bulb were to shatter.
Posted on May 02, 2010
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
Door button does not function for panasonic microwave=need to know how to take the face off so that I can fix it
Take side panels off and press the button through from the back, my husband has just done this tonight on our Panasonic microwave model NN-ST477 as the door would not open. He found a piece of plastic like a hook had snapped off. The door now opens and functions normally. Took about 30 minutes to do . If and when it becomes stuck again we know that we will need a new replacement button. Hope this helpskind regardsChristine
Sep 14, 2011 | Panasonic NN-H275 Microwave Oven
How do yo change a blown light on a NN-T774SF micro wave
just disconnect from the power and take out the screws from the cover around and you will see a plastic color white then remove a screw from them and you find the bulb replace and return all parts back
Apr 01, 2011 | Panasonic NN-T774SF Microwave Oven
Someone gave me a NN-S252WF Serial #6U82280086 under cabinet microwave. They said it would work, but cut off and the light didn't work. They took it to a service tech and he said they had a defective...
Panasonic changed their part distribution a few years ago and mesed everything up there new pqarts distributer in a company called Encompass. they dont typicaly dont stock a whole lot.
A lot has been discontinued.
Encompass
https://encompass.com/
Jun 24, 2017 | Panasonic NN-S252WF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Panasonic NN S254BF
It sounds like one of the wires or serkits are loos so the electrisity is not getting to it all the way I would return it or take it apart and try to fix it your self.
Dec 29, 2007 | Panasonic NN-S254BF Microwave Oven
Panasonic NN-P794SF Microwave Oven Logo
406 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
