Question about Garden
John deere lane rider la135 wont start.
John deere la135 wont start. I believe it might be the battery when I try to crank the rider nothing happens but the headlights come on? I have checked spark plugs and is good.
    Problem Solver:
  • 13 Answers
You don't mention if they are on and are bright or are week. Do they dim when trying to cranks the motor? I would start with checking the ground wire at the battery and where it connects to the frame. Make sure both are clean. From there, have the battery tested and then the starter.
Posted on Jun 10, 2010
I have a john deere stx46 that will crank but not start. Gas is getting to the carb but nothing seems be be coming out the other side of the carb. Could the carb be clogged?
pour a little bit of gas in the carburetor and try it. if it starts for a few seconds it may be clogged and need to be cleaned. change the spark plug first. and try if it wont start then try the carburetor.
Jun 09, 2016 | John Deere Garden
John deere L100 cranked over...wouldn't start...out of gas....added gas, now wont crank over at all
Thou has drained the battery with all your cranking. Recharge unit and now check for spark since you have resolved the fuel delivery issue.
Mar 14, 2016 | John Deere Garden
John deere lawn tractor. Had a dead battery. my son tried to jump it but cables got hooked up backwards, cranked 10 sec. Now turns over but wont start and smokes under the flywheel
Because he shorted out the alternator under the flywheel. There also maybe other damage as these are not protected from reversed voltage.
Apr 30, 2015 | John Deere Garden
My John Deere 1023e won't start
hook a hot side of a good battery directly to the starter and the ground side to a ground on the frame. if nothing happens the starter is bad.
Mar 01, 2015 | John Deere Garden
Why does one blade spin after mower is stopped on my John Deere LA135?
check your blade brake for that blade,supposed to rub against top blade pulley when blades are disengaged,if its a manual engage vs electric clutch
Jul 30, 2014 | John Deere Garden
Wont start light dont work
If choked off. Pull a spark plug. May be full of gas.
Apr 03, 2014 | John Deere Garden
I have the John Deere Turf Tractor and it will not do anything. I have checked all the connections and had the battery and charger checked. All these things are fine. What else could be the problem?
What is meant by anything? No crank, no start, no go??? If battery has charge and nothing is happening, check fuse then go on to switches. A multi-meter and/or a test light should send you to the right area pretty quickly.
Sep 24, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
John Deere 425 AWS no start, no nothing???
Sounds more like a bad starter than a bad coil.
A failing coil usually shows up during hot weather. The engine will start and run fine, then when it heats up, it just dies out. After a few minutes, it cranks again. Then the cycle repeats itself.
The ignition module and coil pack are the same part.
Are you sure full voltage is getting to the starter? There is likely a starter solenoid between the ignition key and the starter. These solenoids can be problematic and prevent the full 12 volts from getting to the battery.
Oct 16, 2009 | Garden
Garden Logo
898 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
