Question about Dryers
Ignitor lights and burns for a few minutes and then goes out, tries to relight but no flame
    President:
  • 949 Answers
The symptoms you are describing indicate the coil on the gas valve is breaking down. The coils are what open and keep the gas valve open to allow the flame burn.
As they age they can breakdown and work when cold or first used then as they heat up the wire breaks down inside and turns the valve off, the system continues to try and relight but with the bad coil it does not.
It may work again after the machine sets idle for a long period of time but will fail again when it gets warm.
The coil kit is about $20.00, the picture and part number is below. If you need instructions beyond what is supplied with the kit let me know and I can help install it.
Posted on May 02, 2010
Frigidaire Gallery Commercial Heavy Duty GAS DRYER Model GLGR331AS1: gas lights and dryer operates for approximately two minutes. Then the gas goes out and approximately 1 minute later the igniter comes...
The flame sensor, ignitor, and coils all are wired together in a complicated circuit so that the coils will not operate untill the ignitor is out of the circuit and is screaming hot. If the ignitor is open or bad the coils will not operate because the ignitor becomes like a thermocouple when screaming hot. So if the ignitor is working and the flame sensor is working properly AND the dryer will work some and then quit, I would suggest to you that the coils are aged and when they get aged they tend to fade and die when used once or twice. It is an aggravating thing to diagnose. Replace the solenoid coils and rock on dude!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 19, 2011 | Frigidaire GLGR331A Gas Dryer
I have an empire heater and the problem that I am having is that when the valve is turned on high or any setting, the flame burns for a few minutes then goes out. It will not stay burning, we have to...
Have you replaced the thermocouple? Have you cleaned the Pilot? Do you have a strong pilot flame and is it touching the thermocouple? Sometimes if you don't have a good strong pilot is that when you turn the main gas on it pulls the pilot flame away from the thermocouple and cools it off so it drops the signal. Check the gas pressure should have 10 to 11 "WC of manifold pressure.
And you could have a bad gas valve. Hope this helps.
Jan 02, 2011 | Sunbeam Heating & Cooling
Broil on gas oven runs for a few minutes then pops, goes out then relights. flame come sright back to gas orfice, any suggestions
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 24, 2010 | Frigidaire FGF378AC Gas Kitchen Range
Whirlpool dryer lgr6620pq1 flame goes on for only 6 minutes the orange glo tries to relight but no flame. can I get a repair manual for it?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Dryers
AFTER LIGHTING MY RICHMOND 6G40-36F1 WATER HEATER IT LIGHT FOR A FEW SECONDS AND THE FLAME AND THE PILOT LIGHT GOES OUT. WHAT CAUSE THIS TO HAPPEN?
There is air in the gas line. The best way to get the air out, is with the gas on, loosen the nut that attaches to the gas valve and make sure you can smell a little gas, then reattach the gas line, making sure everything is tight, and then relight the pilot making sure to hold the pilot light button down for at least 1 minute. Please rate
May 24, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 11, 2009 | Dryers
Frigidaire Gas Dryer not heating up, Model FSG447GHS0
check vent and vent ehaust tube for blockages..
Dec 29, 2008 | Dryers
Kenmore no flame
Is this the scenario? It lights for a few cycles or maybe not at all. The ignitor glows and goes out but no flame. Comes back on then does the same thing. If so it could be failing coils (those two black cylinders on top of the gas valve assembly). There's a kit that includes both and it's a fairly simple job.
Jan 03, 2008 | Kenmore 75944 Gas Dryer
Open Questions:
Dryers Logo
16 people viewed this question
Top Dryers Experts
