Question about LG 32LC2D Television
Sky plus remote code for lg 32lc2db
I have a lg 32lc2db and a sky plus box and remote with version 6 and cant get any of the codes to control my tv i have tried all the ones sky supplied but no joy any help please would be appreciated
5 Suggested Answers
SOURCE: Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Posted on Aug 04, 2008
  • 325 Answers
SOURCE: Can't find a code for my ver 6 sky remote for LG50PS3000 TV
on your remote:
TV,
red + select (blinks twice)
TV,
0056,
press VOLUME button if this does not work press TV then repeat
once the VOLUME button works your telly press the SELECT button (stores the code).
If this does not work its because you have a rev 6 remote. take the cover off the battery case and it will tell you the rev number.
I install sky day in day out and ive only had one LG telly that did not accept this 0056 LG manufactor code.
The HD rev 8 remote will work no problem if you follow my steps..
Hope this Helps
Little Dish Fitter
Posted on Sep 01, 2009
SOURCE: SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Posted on Sep 02, 2009
EngineerMC
  • 186 Answers
SOURCE: sky remote code for lg m227wdp
press tv button
then red and select together for 2 seconds the led should blink twice
enter the code
press select
try it...
one of these codes should work... but its a bit trial and error 0056 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
good luck
Posted on Feb 14, 2010
I cant get sky to work on my LG plasma tv
Hello
Codes to check for LG with Sky are;
065 244 405 318 037 398 191 459 245 389 080 275
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions
Mar 12, 2011 | LG 32LH30 32 in. LCD HDTV
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Dec 17, 2010 | Televison & Video
Cant find right code for my sky remote for 42lh2000
I have just purchased a LG 42LH2000 Tv but can't seem to get my Sky Plus control to work the volume does anyone have a code to help
Jun 18, 2010 | LG 42LC2D 42 in. LCD HDTV
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Codes are 0065, or 0405,or 0037
Code are 0065, or 0405, or 0037
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
Aug 11, 2009 | LG 42LG30 42 in. LCD HDTV
42LH3000 I CANT GET MY SKY REMOTE TO WORK WITH THIS TV. I NEED A CODE IF THERE IS ONE
Once you have the ver 8 controller - code 1176 should work
Code for sky+remote control for lg tv 50pc56
Haing same problem. Think it's the version of the remote control unit you have. If you have Rev 8 (it tells you inside the back cover) then some codes should work, if rev 6 or rev 4 it can be tricky. Try the following, but can't guarantee anything:
0742 0743 1962 0065 0405 0318 0275 0037 0391 0137 0459 0389 0398 0191 0244 0502 0245 0584 0311 0634 0072 0246 0060 0206 0065 0743
Feb 08, 2008 | Televison & Video
Sky remote code for lg 37lc46
for sky plus remote ver 8 the code four number is 0206
the three number code is 206
Nov 16, 2007 | Televison & Video
Sky+remote code for my lg tv
The cose you need is 0206
Sep 15, 2007 | Televison & Video
Televison & Video Logo
125 people viewed this question
Computer Repairing
Computer Repairing
