Question about Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger
Charging problems with WORX Trimmer/Edger
My battery runs down pretty fast, then when I plug the battery into the charger the light stays green then sometimes afer a while it goes to red and starts charging, after a while it goes back o green and the battery is charged but not fully, it loses power in about 15 minutes.
  • 279 Answers
SOURCE: is the battery for the worx 18v string trimmer
All you have to do is check the sizes of the batteries. If they are the same size, by that I mean shape and dimension, there is no reason you cant use them on different equipment. ...Lee
Posted on Sep 14, 2009
rycgl
  • 1545 Answers
SOURCE: I am having problems with the battery on my worx
You can determine exactly what is going on by using a small handheld voltmeter. They are inexpensive, easy to use and come in very handy. Just test the output of the charger (after noting what the volt-output-rating is) by touching the leads of the meter to the terminals on the charger. If the charger is working at all, this is not a dangerous test. Conversely, test the output of your batteries by touching the leads of the voltmeter to the terminals on them. I suspect the charger is bad because after they overheat, they quit working and some don't last very long. I don't think YOU are doing anything wrong, just maybe the companies that manufacture these 2 electrical products are.
Posted on Oct 14, 2010
  • 130 Answers
SOURCE: battery charger on a Worx
Flashing red light indicates battery is bad. Flashing green light indicates charger is bad.
Posted on Feb 21, 2011
  • 3074 Answers
SOURCE: My WORX trimmer and edger
sounds like the battery needs replaced
Posted on May 07, 2011
  • 207 Answers
SOURCE: I used my Worx trimmer
Your battery is shot. I had one of these, the batteries are really cheap and don't last long. If you can afford it, ditch the Worx and buy a quality trimmer at your local hardware store. If you are short on cash you can buy new batteries online.
Posted on Jun 06, 2011
WORX BATTERY CHARGER. when i PUT THE CHARGER ON THE GREEN LIGHT COMES ON.
Mike, The red LED is suppose to be on when you insert battery, the LED will go green when battery is charged. Look in your manual, Pg. 11 charging instructions. Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://pdfstream.manualsonline.com/7/72bd8a7a-cf98-43d4-92b7-a15bc78eb6bb.pdf
Battery Driven String Trimmers
How to Check Li ion Battery
Jul 15, 2016 | Worx Gt Wg151.5 18v Cordless Electric...
WORX 24V charger won't charge
I'm having the same problem. Worked great then didn't last as long. Now I'm stuck with this piece of crap useless piece of equipment. I'm back to spending too much time trimming with scissors since I can't afford a new battery non the less a new trimmer. Thanks a lot WORX! It doesn't Work! I'll never buy another of their product!
Aug 26, 2012 | Worx 24-volt Cordless Electric Lithium-ion...
BATTERY IS COMPLETELY RUN DOWN, PLUG INTO CHARGER BUT LIGHT STAYS GREEN NEVER TURNS RED & DOES NOT CHARGE BATTERY???? ONLY 1 YR OLD. WHATZ THE FIXXXXX?
I had a similar issue with my Worx battery.
Check to see if you are eligible to receive a free battery replacement:
www.worxbattery.com
Good Luck!
Aug 03, 2011 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
My worx will not stay charged... the charger goes green after about 10 minutes and only runs for about 5 minutes...
it sounds like the battery has seen better days. a battery will get a "memory" and after while it could fully charged as far as the charger know but only hold a little charge. with the advices in batteries they shouldn't do this but they all do wear out of time. I would get a new battery, and everything should be just fine. With the any new rechargeable battery you want to make sure that you charge it completely and drain it the whole way before recharging.
Best of luck
Mark
Jun 23, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Battery charger on a Worx Gt Trimmer Battery is blinking red what is the problem
Feb 21, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
I am having problems with the battery on my worx gt trimmer. It will not stay charged even though the battery charger indicates a green light. What am I doing wrong? I put it back on he charger it will...
Oct 13, 2010 | Worx GT WG150-2 18 Volt 10 in. Cordless...
The battery on my Worx GT doesn't seem to hold it's charge. I have actually taken it directly off the charger when the light is green and it doesn't have full power. Sometimes it does. The unit is 3...
the first time the Worx GT worked great since then I took it off the charger and it won't go more than five min. without going dead. I'm back using my gas trimmer what's up ith th battery on the Worx Gt
Jul 16, 2010 | Worx GT WG150 10 in. 18 Volt Cordless...
Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger Logo
159 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
