Question about Yamaha RX-V595A Receiver
Reciever won't switch back on
My RX-V595 AV Receiver switched off and wont switch back on Doug
  • Anonymous Mar 25, 2014
    rx-v595
  • 95 Answers
You need to take it to the nearest yamaha service centre. Unit could have had a surge or blown a fuse.
Posted on May 26, 2008
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Smart TV but reveiver does not have HD plug ins
I would input everything directly to the tv via hdmi, then take the optical audio output from the tv back to the receiver.
Jan 04, 2013 | Yamaha RX-V595 Receiver
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
Problem with potentiometer Does anybody know where is possible to buy volume- potentiometer for Yamaha RX-V595RDS? When I turn receiver on sometimes one output chanel (speaker) is silent till I turn...
A little more triage would be in order before you take a knife to it.
Turn the volue to something in the middle.
If it's only an analog source doing it I would suspect a bad switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Mar 21, 2011 | Yamaha RX-V595 Receiver
The sound will suddenly go off on my Yamaha RX-V595 receiver. I can turb it back on and it will play for awhile and then turn off again
This is a classic over heating problem. There are 2 likely causes - hope for the first.
1. The speakers or wiring have a problem and draw too much current from the receiver. Carefully check your wiring. If it looks OK, leave both speakers disconnected and turn the volume control all the way down. Power the unit up. If it stays running, then try one speaker then the other (at low volumes to avoid damage) and see if one makes it shut down. If it does not stay running then see #2.
2. The power amp circuitry of the receiver has an issue causing it to overheat or the overtemp circuit is faulty and it thinks its overheating. Either way, this one needs professional help.
Good luck
Oct 23, 2010 | Yamaha RX-V595 Receiver
Not getting on yamaha av reciever rx-v363
IF IN WARRANTY SEND BACK FOR SERVICE...
Apr 04, 2010 | Yamaha RX-V363 Receiver
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
I need a display bulb for a yahama rx- v850 av reciever
The display bulb is a 14 volt bead style lamp about 0.150 inches wide with wire leads. You'll need to cut the old bulb off the two -pin cable assby and wire the new lamp into the existing wires.
partsexpress.com
mcmelectronics.com
or
studiossoundelectronics.com should have lamps for that
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
Yamaha RX-V595A Receiver Logo
183 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
