Question about Bugaboo Cameleon Stroller
Bugaboo wheel removal
How do you install large replacement wheels?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 20 Answers
Hi
www.buggypitstop.co.uk/ check it out....send them a msg and they would help.
thanks
Posted on May 05, 2010
    Guru:
  • 541 Answers
Squeeze the small metal wire pins like a circlip at the hub where the wheel goes in and this allows you to release the wheel. When you put another wheel in grip this again with your fingers and guide the wheel in, when it clicks you know you have in in properly and it should lock in place.
Posted on Oct 30, 2010
Need to buy a new bugaboo cameleon front wheel circlip and dome
Hi Barry
We'd recommend you contact Bugaboo for assistance.
Bugaboo Official Site
Mar 20, 2014 | Bugaboo Baby Gear
How to fit bugaboo cameleon in travel bag
Fold it down just like you would to put in the car, then remove the two large back wheels and put them in the wheel bag, and then either turn both front wheels flat or take both swivel wheels off and place them inside the bag on top of the frame then place the seat on top.
Jan 14, 2013 | Bugaboo Cameleon Baby Gear
HOW TO REMOVE THE LARGE WHEELS
Here is a link to the manual. It's very simple with the brakes off you just push the ends of the little spring clip behind the wheels together. Picture on page 11www.pramfix.com.au/baby_repairs_spares/instruction_booklets/Bugaboo%20Cameleon%20En%20UK%20Clip%20Version%202007.pdf
Nov 04, 2011 | Bugaboo Cameleon Jogger
I'm trying to find the bearings on my bugaboo bee to clean them. where are they?
The front wheels are held on by capped star washers. Removing them will damage them so you need to find replacement washers before you try that. The back wheels can be removed but you need two hex keys. I just stick the wheels in hot soapy water, hose off and wipe dry. I than spray with silicon spray. If you are having the infamous Bugaboo Bee front wheel jitters try putting a rubber washer over the swivel pin.
Jul 14, 2011 | Bugaboo Bee Stroller
Bugaboo wheel shassy on wrong way
I'm assuming you put the front wheels on from the wrong side. You need two large screwdrivers to slip down between the top stub of the wheel and the tube of the frame to press the two tabs in to release the wheel.
Feb 19, 2011 | Bugaboo Baby Gear
How do I take off my front wheels off my chameleon
You can down load manuals from www.bugaboo.com the front wheels are held by two plastic tabs at the top of the wheel assembly. These are pushed together to let the top of the wheel assembly pass down out of the front wheel mounting. They are quite firm the first few times you remove them. If you have put the wheel assembly into the wheel mounts from the wrong side you'll need two large screwdrivers to slide down into the mount to reach the tabs.
Feb 09, 2011 | Bugaboo Cameleon Stroller
One of the front swivel wheel on my bugaboo cameleon is not rotating. Is there a way to remove just the wheel?
You can buy wheels from Bugaboo including a bigger set called snow wheels. The wheel is held on an axel by capped star-lock washers. Prizing them off usually makes them unusable so don't try unless you found replacements. Try soaking the wheel in hot soapy water than a good dose of silicon spray.
Jan 27, 2011 | Bugaboo Cameleon Jogger
Cant fold the chasis
send it back to Bugaboo for a replacement. Assuming it is under two years old
Apr 16, 2009 | Bugaboo Cameleon Stroller
Bugaboo gecko tire flat and tube no longer attached to wheel
First try pushing the valve out while your pumping with bugaboo pump. If it blew out need to call bugaboo you have a two year warranty and they will send you a inner tube or a new wheel.
Tel# 1-800-460-2922
nathalie
Dec 04, 2008 | Bugaboo Cameleon Jogger
I'm trying to install the wheeled board on the bugaboo. Have followed the instructions - but there seems to be a floor as the wheeled board is too wide for the clips its about 5mm too large. Anyone else...
We have installed the board and have found that the fitting is quite tight. I have noticed that the clips slide slightly when turning the bugaboo over to fit the board, so you need to keep pushing the clips back into place....hope it helps! As an aside, we have bought the seat attachment (not sold/made by bugaboo) which has been fabulous...it has certainly helped when out with the two children and has been the envy of lots of other little ones!
Aug 09, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Stroller Logo
297 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
