Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
I was using my hard drive with 2 partitions. 1 partition of about 500 GB was used as a Time Machine Backup for my MacBook Pro. The other half of the drive was used as a general data dump for documents, photos, and videos. I dropped data into this side mostly from Mac OS 10.5 but also from the Windows XP SP2 partition of my Intel-based Mac. After trying to connect my drive to my usb network router so that it could be connected to my computer on a network, the drive would not load. It was not recognized on the network and then when I tried to reconnect it directly to the computer, the Mac OS keeps saying the drive can't be read and gives me the option to initialize it. I didn't initialize because I didn't want to loose the data already on it. I tried to use DiskDoctor software to recover from what I thought was a formatting issue but that did not work. I checked some blogs where people claimed to use Mac DiskUtility and partition using GUID setup. When I tried that the Disk Utility claimed there was an input/output error. I'm not sure if the drive can be solved with software or if it is physically damaged. About a week before I got all these problems the drive fell off a table. The case was offset but I just snapped it back in place and it continued to work without problems. I don't know how to get my computer to recognize it without erasing it and loosing all the data it has.
  • 2 more comments
  • sirianous May 03, 2010
    Is it okay to open the outer case? I opened an internal hard drive once only to find out that the slightest speck of dust can ruin it.
  • sirianous May 06, 2010
    I opened the external hard drive case and connected the SATA drive directly to my computer using Bytec Drive Mate. It still said the drive was unreadable and if I wanted to initialize it. I opened disk utility and first tried to repartition the drive. It repartitioned but when I reloaded the drive I got the same error message and whether I wanted to initialize it. I said yes but that just automatically opened disk utility again. I tried first aid but it was all grayed out. I tried repartition but that didn't solve the problem. I then tried to erase and start over. It erases but then goes into partitioning automatically at which point the blue progress bar freezes and nothing gets done. Also I should mention that the 1TB drive keeps displaying as 2TB in disk utility
  • sirianous May 07, 2010
    No, the drive is out the case and I removed their usb adaptor and attached my own bytecc drive mate adaptor directly to the SATA hard drive. I know my drive mate works because I have other hard drives that successfully connect. I think the problem is with the hard drive itself. Outside of the external case I can hear the drive better and it doesn't sound like a healthy drive. It makes clicks and whirls different than usual.
  • sirianous May 10, 2010
    Thanks for your help. I will wait for the replacement drive and then try to recover software to the new drive.
  • 1,555 Answers
I received the same type of ehdd at my repair bay three days back. I tried it with linux 98 and even dos but to no avail then I concluded that the problem is hardware failure. I replaced the usb cable still it didn't worked. At last I de-soldered the connector on ehdd and replaced with a new one and it worked perfectly. Hence, I recommend that you try it with linux mount command and if it's not detected over there then you are required to change the connector.
Posted on May 02, 2010
  • 1 more comment
  • Aruna Singh
    Aruna Singh May 03, 2010
    External HDDs are entirely different than Internal ones. Internals were vacuum packed double shielded shock proof screw tight and many more things but external ones are entirely different . They are push-fit no questions of vacuums the only caution one has to take is the data/power cables inside it they are delicate. No scratchings on the plastic thing inside it. If you can wait upto tomorrow (means 24 hrs from now or may be 22) I can take a pic of my open E HDD and point out the correct things on those pics.
  • Aruna Singh
    Aruna Singh May 05, 2010
    Sorry for the delay. Here is what all necessary for you to know.
    http://www.ransackery.com/western-digita...
  • Aruna Singh
    Aruna Singh May 09, 2010
    Now you have reached to a place where you know as a tech neither I can do anything nor you can fix it. Thats the same driver which I told you as an internal drive vacum packed and all that dust free area things. It's not so that such HDDs cannot be repaired. They can be repaired but the cost of the repair is going to exceed the cost of HDD itself. Thats why no one opts for repair and such units are known as BER (Beyond economical repair).
  • 55 Answers
If the data is very crucial and you cannot afford to loose it you can go to places live "geek squad"or "comp usa" or "drive savers" coz you would not want to take any adventure witht he data your self , if it not as important than try to connect the hdd first with the windows os computer then mac and see what you can recover infact you can also use any data recovery software too,
secondly the hdd are usually very sensitive as they have got disks running inside the box so if it fell down and you have took out the data ,then format it and see if the problem coms again if it does then buy a new hdd .
Posted on May 07, 2010
  • 1,472 Answers
Sirianous
To clarify when the drive is showing as a 2 TB drive is the drive still inside the external case.
It sounds like the controller on the drive or the case is bad.
Issken
  • Will Hartford
    Will Hartford May 09, 2010
    sirianous
    Unfortunately if the drive is making clicking noises then something happened the drive its self when it got knocked over.
    If you have critical data on the drive you might be able to recover the data. You might check with your local computer store to see if they have a program that will run the recovery. You might also do a search for one your self. The programs run normally around $300 to $500 thats why I recommended you check with your local store. I normally charge around $100 because it will try but my test rig for 24 hours and I need to look in on the drive. Also to run the recovery you have to have free drive space equal to the size of the drive because you will need a place to store the covered data. Note even if you do not use the whole drive some old deleted files my get recovered.
    Also note there is recovery services out there that will pull your platters out of your drive in a clean room to recover your data but those start around $1000. So if the data is not critical data I would try just the software recovery. But if you want to do this you need to stop messing with the drive as the more your do the less likely you will get any data recovered.
    Let me know if you have any more problems or questions
    Issken
    http://www.fixya.com/users/issken
What is the largest option available for xbox 360 hard drives?
as of now, the highest memory xbox hard drive offered is 320 GB, which comes out to about 314 GB of free space because the system reserves 6 GB
Jan 29, 2013 | Video Game Consoles & Games
HI I have a desktop with : *MSI Motherboard with Nvidia chipset on it *Intel Core 2 duo *2 GB SDDR2 RAM *500 SEAGATE HDD I created four partitions on the HDD , i had bad sectors on the fourth partition...
Have you considered checking your DVD writer? Also, you might already have a faulty hard disk drive.
You can try any of the following:
1. Double check to see if your Windows 7 installation disk is dirty (clean it using a lint free cloth) or has many scratches. (Your DVD reader/writer would really have a hard time reading scratched disks.)
2. Borrow another DVD-ROM from a friend and use it to install Windows 7 on your computer's C drive.
3. Check to see if ALL cables are properly connected. i.e. SATA, power cables, etc.
4. You could also try to make your 500 GB HDD as a slave drive so that you can backup your files to another media if it works. (Backup to another external hard disk drive, burn it to DVD's, etc.)
5. LISTEN carefully if your hard drive makes unusual noises like unusual clicking, bumping, and/or scratching sound inside your hard disk drive. If it does and as a last resort, replace your hard disk drive.
Nov 23, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Nov 22, 2010 | Microsoft Windows XP Professional With...
I bought a Seagate Free Agent Desk External Hard Drive 500 GB for use with Windows. I Have an iMac and wish to reformat it for use on my Mac Operting System Version 10.6.4 (Snow Leopard). Please...
In Disk Utility click on the Partition click on the Current Volume Scheme drop-down menu and select One (1 partition) from the Partition Schemes provided: Click on the options button and chose either the GUID Partition button or the Apple Partition Map button click OK Select other options as desired (e.g., Volume Name Format etc.). Click Apply the Partition Disk screen opens click Partition
Time Machine may open asking if you would like to use the volume for backups. Click Cancel to proceed
Oct 21, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
HOW TO PARTITION FREE AGENT 500 HARD DISK. i HAVE NO PRIOR EXPERIENCE AND WOULD LIKE TO ENSURE EXISTING DATA IN FREE AGENT REMAINS INTACT. pLEASE ADVISE
First, copy all of the data from the drive to another as a backup.
Now the drive already has a partition or you would not be able to store data on it. Therefore, you could only be speaking about dividing it into multiple partitions.
Therefore you delete the exisiting partition and then create smaller partitions. In Windows you will be limited to 4-partitions.
I hope this helps.
Sep 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Partition external hard-disk
You can partition your hard drive using any of the available free partition tools such as EASEUS Partition Master or Partition Logic. You can even buy tools like Partition magic to do the same job.
Please rate if Helpful.
Thanks
Apr 12, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My brand new seagate hard drive is showing on 120 gb space on partition time?
it means your hard disk have 120 gb capacity, you can make partition according to your requirement.
Apr 02, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
Sharing Lacie with MacBook & PC
Unless you use a specific software package to resize the existing partition (partition magic et al), the original partion and contents are effectivly erased... they can be recovered using disk recovery software in most cases though
If you still have the source files and both systems can see and write to their respective partition of the Ext HDD, then the easiest way to move forward is to just copy your files back onto the assigned partition.
Jul 14, 2008 | LaCie (301146U) 320 GB FireWire 400...
Partition
decided to use Free Agent Pro dedicated to Time Machine and purchase a separate harddrive to just use as a 2nd external drive to store photos, etc.
May 28, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
