Question about LG WM1814CW Front Load Washer
Cold water will not shut off even when washer is off.We left unit unpluged over nite and still have same problem LG washer # wm1814cw overfills
  • 549 Answers
You have a stuck cold water solenoid valve.
Try openning the machine and tap on the cold solenoid valve.
If this dowes not work, you may have to replace the valve.
Posted on Mar 25, 2008
Lg wm2016cw
Check that the pressure switch tube is connected to pressure switch. Check that the water inlet valve is not stuck open. To check start washer, turn washer off, if water continues to flow the valve is stuck open, replace.
Aug 01, 2014 | LG WM1814CW Front Load Washer
FE Code for model WM1812CW LG Washer
Hot water inlet valve most likely needs replacing
May 14, 2017 | LG Washing Machines
Washer stopped and door is locked shut and will not restart even after unplugging
Probably a faulty interlock which stops the door from opening when washing.
Apr 03, 2010 | LG WM1814CW Front Load Washer
LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Jul 12, 2009 | LG Washing Machines
I have an LG WM1814CW not getting .
At first we did not see any filters in the water hoses ... but after pulling the machine away from the wall we did find one - and it was clogged shut. So removing the material DID fix the cold water supply problem.
Thank you.
Feb 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Did you check the simple things first?
Often, one of (up to) three screens are in line with both water feeds; one at each end of the connecting hose, still another at the input to the control valve.
Feb 07, 2009 | LG WM1814CW Front Load Washer
Hot water runs constantly - overfills
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
Jan 11, 2009 | LG WM-2277HW Front Load Washer
I purchased a front loader washer and I only have a cold water line no hot,I hooked it up and the machine comes on but no water comes in the machine....can someone please help me figure this out??????
ok no problem where going to try this but your going to have trouble in the end...since you only have a cold tap ,,use a y hose to booth vavle dont cap of the hot,,,now you purchase a unit that has atc,,automatic temperature control..meaning the unit control how hot or cold the water will be in degrees,,,when you start the unit it puts hot in at the start even in a cold wash to break down the soap in the dispencer,,it doent know if you use powder or liquid,,so it just shots hot water though for a few second,,now that comes back to the begging,,if you put clothes like whites and that atc does nt sense that hot water the unit will stop until it do,,and you will get a code,,im here onthejob
Jan 02, 2009 | LG WM1814CW Front Load Washer
It is possible that the water solenoid is stuck open, sometimes they can be cleaned and yet sometimes they will need to be replaced
Oct 21, 2007 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
261 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
