Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan 2375 carburetor adjustment, please explian red abd blue adjustments and procedure
    President:
  • 2,220 Answers
Blue = "L"ow, Red = "H"igh If running just do the following:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment may be indicative of a larger problem.
If not running start with "H" and "L" 1.5 turns from lightly seated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
Polan 2450 chainsaw will not start when cooler that 60f degrees.
Check the plug and clean if needed. Prime with 1 teaspoon of gas or starting fluid into the cylinder through plug hole, replace plug and try again. Adjust carburetor to run properly at both low and high-end and idle.
Oct 26, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 2375 will not idle
This sounds like a simple carb adjustment issue, however there is a special tool required to adjust the mixture, part no. 530035560, once you have the tool richen the L scerw on the carb by unscrewing it by 1/4 turn out, before making this adjustment, try just increasing the idle speed screw on the carb, this requires just a normal screw driver, do not increase it to the point ehere the chain is moving on idle.
Mar 04, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Can you please tell me what the carb adjustments are for the Poulan 18in. wild thing chain saw?
"L", "H", and "T" adjustments are all explained on the link. It is a very good carburetor setting procedure.
Start with “L” & “H” needle valves 1.5 CCW from lightly seated, then adjust for performance as follows.
Lou
May 11, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan chainsaw 2.5 ci farmhand boggs out when choke is turned off?
Check for plugged fuel filter, hard/cracked/rotten fuel lines, plugged muffler and air cleaner, or loose fasteners on the carburetor. If no help, dismantle the carburetor and check the lower rubber diaphragm for hardness or cracking. Make sure to have fresh fuel mix in the tank. If the L jet needle has a slotted-head, a small screwdriver can be used to back out the adjustment CCW about 1/4 to 1/2 turn. If the adjustments have 'D' heads, you will need to take it to a servicing dealer that has the proper tool. Hope some of this helps!
Apr 19, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wood shark carb tune up have a blue & red srew which one is low speed
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 21, 2010 | Poulan Garden
Carb adjustment for a Poulan Wild thing 2375
Start at 1.5 CCW from lightly seated then tune for performance like this:
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 19, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild thing, 18", will not idle after throttle is released.
Need to change the fuel filter. It is inside of the fuel tank on the end of a small gas line. You need to carefully fish it out of the tank. Usually a piece of stiff wire with a hook bent on the end of it should do it or possibly a pickup tool. Then I'd recommend readjusting the carburetor. The default setting for the H and L carburetor jet is usually to turn them in all the way till they stop and back them out a turn and a half. You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Nov 28, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 295 farm boss chainsaw
Try to adjust the air and gas intake pin. It is a screw type dial usually found sticking out the carburetor. You are tuning your carburetor, so you will have to test different adjustments until you get your desired running idle and power. I suggest you start with adjusting the air intake screws to decrease air supply going to the cumbustion chamber, It will probably make the chainsaw run when you give it a throttle.
Keep me updated
Mark
Oct 23, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
973 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
