Question about Tippmann Cyclone Feed System
Tippmann a5 cycles just not fast
I can shoot the marker and the cyclone cycles but if I try shoot twice with little time between shots it won't cycle I have to wait like a second or so
    Problem Solver:
  • 19 Answers
The cyclone is supposed to feed at least 15 p/s if you are having that problem I would take apart the cyclone make is clean, you would not believe how much paint can get in there. I would check the hose and after that the o-ring on the cylinder piston. Another thing that might be messing the cyclone is the speed on the marker or the valve itself not sending the amount of CO2 or air to the cyclone. I hope this helps.
Posted on Mar 18, 2011
WFW94HEXW door won't unlock and Door Lock isn't lit
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
2) if do not obey press and hold END OF CYCLE, wait about 10seconds
3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
God bless you
Jun 21, 2012 | Washing Machines
1998 escort don't start first time,I have to crank the key at lest twice befor it starts, then its ok starts fine unless stand about for hours,then the same problem,can you help me pleases.
sounds like the check valve in the fuel pump is not keeping the fuel line full of fuel. try cycling the key to the on position a few times prior to cold start. wait a few seconds between each time you cycle it to on. this allows the fuel punp to run for a couple seconds each time, which will fil the fuel line. if this works, then that is the problem, sadly the only way to cure it, is to drop the tank and replace the fuel pump. good luck.
Dec 21, 2010 | 1998 Ford Escort
I just bought a used Cyclone 2 table, and am thinking of replacing the wood handles with the new plastic ones like on the T-3000. Is that possible? Do i need to use a converter or something?
Absolutely! Do it. I installed them on my cyclone 2 and the game is so much better. The handles are a little heavier which slightly effects the shot timing but WOW! The shots are so much more powerful! I on many occasions popped one in from the back two man, the ball traveled thru the channel, entered back on the field, and into the goal a second time on one bad *** toe shot! Do it! It's well worth the upgrade.
Oct 10, 2010 | Dynamo Tornado Cyclone Foosball Table
Control locked light is on
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you set the timer for an intermatic pool timer? There are two sets of green & red markers, but will not stop at correct time.
Put a green marker at the time you want to turn ON. Put a red marker at the time you want to turn OFF. You can up to set two cycles per day. Make sure the markers are arranged green-red-green-red for separate cycles. If there are same color green markers in a row the second one will have no effect since it is signaling the same action as the marker ahead of it.
Nov 24, 2009 | Intermatic Mechanical Timer Switch - Pool...
Ho do i program a keyless entery remote on 2001 toyota prius.thank you in advance.
Try this:
key not in ignition.
driver door open-others closed
driver door unlocked
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice
this is rewrite mode,have all remotes to reprogram
it will clear any lost remotes.
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possesion,you are done.
to end mode open door or insert key into ig.you can do up to 4 remotes.read this a couple of times to get the sequence down.there are time restraints,but if you go in order it will work.do not wait more than a second b/t each step and you will be ok.i know from experience that you can do this as fast as you can and it will enter mode.if steps out of order or you wait to long it wont.print this and have in lap,read ahead of what you are doing.good luck.
Jul 06, 2009 | 2001 Toyota Prius
Starting a second remote for a 2004 toyota corrola
I believe you need to programn a second remote? Try this.
Jun 13, 2009 | 2003 Toyota Corolla
1997 camry remot key
Try this.
Jun 10, 2009 | 2001 Toyota Camry
Can you add clothes to washer after cycle starts?
Not really. Even if it lets you it will pump out the water first. This kind of defeats the purpose. If it didn't pump out the water it would spill on the floor.
Jul 03, 2008 | LG WM2688H Front Load Washer
Camera not taking pictures
The camera may be trying to tell you that your flash is turned off in Auto mode, but to get a proper exposure you will need the flash turned on. Try turning the flash on and see if that works.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
Tippmann Cyclone Feed System Logo
157 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Tom Chichester
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
