Question about RCA TruFlat 27F520T 27" TV
Trying to connect the TV Model 20F420T withy DVD player all I get is a bluescreen
  • RCA Master
  • 736 Answers
I'm sure you've tried this already but if not try another composite (red, yellow, and white) cable. Try the av jacks in both the front and the back. Try another cable besides the yellow composite cable i.e. S Video. Try the DVD player on another television first to see if it is working. Try another DVD player or VCR or Wii or etc. to make sure an image displays on the television from it.
Posted on May 02, 2010
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
Can not get the DVD player to record to our new LCD TV. Worked fine with the older CRT model. It will play OK. Do I need an upconcertter to make this work?
What kind of connection (wire) are you using to connect the DVD player to the TV? Is it composite (RCA, yellow), component (3X RCA, blue, red, green), S-video (Mini-DIN, like a computer keyboard or mouse connector), DVI (Like a wider computer monitor connector), HDMI (Wider and thinner but like a USB connector)?
Apr 15, 2008 | Televison & Video
Rca tv model 20F420T. tv is fuzzy and says "fpa lock" i cant get it back to regular cable
FPA lock option is located under TV setup. I just turned mine off and on without problems. Hopefully, your reset is effective.
Sep 27, 2010 | RCA 20F420T 20" TV
My RCA TruFlat Model No. 20F420T shuts off at will. All the timers are set to off, any ideas?
HI,,
ITS NOT PROBLEM WITH TV TIMER...
ITS PRBLEM WITH TV AC TRANSFORMER WHICH IS INSIDE,,
ONE OF THE POSITIVE COIL INSIDE TRANSFORMER ITS SHORTING,,
APPROACH TV TECHNICIAN...
Nov 11, 2009 | RCA 20F420T 20" TV
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
Dec 21, 2007 | Televison & Video
Disk won't load
I would verify that connections between the DVD player and the TV; then go into your DVD’s control panel and re-set to original factory settings. I would also make sure that your TV’s settings are set to the correct connection settings as well.
It would also be nice if you included the make, and model of the DVD player and which connections are you using to connect to the TV.
Nov 10, 2007 | Televison & Video
RCA TruFlat  27F520T 27" TV Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
