Modems Can I install a modem in one side of my home for my wife and another in my office. We have cable intenet service and i would like to have a modem in each location. I know I can go wireless but this is difficult in these locations
    Genius:
  • 3,587 Answers
It's possible..but your cable providor needs to authorize both modems on the same line, from a technical aspect..
Posted on Mar 25, 2008
SOURCE:
Cannon mx 330 printer/fax. I plugged into the comcast modem for Tel 1 line then to the back of the cannon fax L. that didn't work so I connected it to the telephone line on the back of the fax..Help
The Pixma MX330 Line port needs to be connected to a POTS (plain old telephone service) line jack with an RJ-11 cable. A standard corded telephone or the base of a cordless system gets connected to the Tel port on the MX330. The Comcast modem connects devices to the internet. You might be able to use a VOIP (voice over internet protocol) service between the MX330 and the modem. You will need the appropriate hardware (MagicJack, Ooma) in between the modem and the Pixma and get an assigned telephone phone number.
Generally, you will need a compatible router to share the cable modem's internet service between any computers and a stand-alone VOIP system like the Ooma.
I hope this helps. Please add a comment with more about your Comcast hardware for additional information. I know my home's fiber-optic modem service does support POTS, in addition to the internet and TV service. Each service has their own wiring/jacks that go back to the modem.
Jun 28, 2018 | Cannon Office Equipment & Supplies
Internet connection
if you are use a modem to connect internet then check list of things like---
1) first check your modem are work properly or not. If all lights are blink then ok or check the modem light and pc light carefuly
2) if modem are work properly then install driver which is provided by the ISP.
3) after that right click on your computer icon and goto manage , goto device manager from the left side list where you can see your new device are connected which will be show as "yellow question marks" then right clik on it get update driver.
4) update driver nd restart the computer.
your internet will be connected otherwise conatct with your intenet provider.
May 04, 2011 | Computers & Internet
How to set up password
insert the disc supplied by your ISP internet service provider then enter the the user name and password you provided to your intenet service provider ISP then just follow the prompts
hope this helps
Dec 22, 2010 | Arris Surfboard SBG900 Modem Cable Modem...
Bought a Belkin router model # f5d8326 4 v2 was told this worked for cable modems not working yet
Make sure the modem is configured properly so it would detect the router. Most of the time, modems now has DCHP capability, meaning it has the ability to hold the username and password you ISP has provided you. The most effective way of making modems work with routers is to bridge the modem first before connecting the router.
Bridging the modem is done by opening the interface of the modem. To pull up the interface of the modem, type the default gateway of the modem in the address bar of your browser(intenet explorer)
Look for the "connection configuration" button and choose "bridge ethernet" as the connection type.
Once the modem is bridged, connect the router to the modem, then configure the router to set the connection type to pppoe. Once done, type your username and pw your ISP have provided the save the settings. This should cpnnect you online..
May 12, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Arris Modem connected to Mediacom Service
I didn't have incoming calls for a year (didn't mind, no telemarketers). But I fixed today.
Check with your home alarm company. Turns out they can download a signal. No, it wasn't the computer's internal modem, it wasn't the phone/cable company or the arris modem.
No need for service call.
Jul 13, 2008 | Arris Touchstone 450a (CM450) Modem
Ethernet
The internet cable fed to your modem by your ISP if faulty.
Jun 29, 2008 | Computers & Internet
Missing Modem RCA dhg525
Take the modem out and look for any brand names such as aztech etc and look @ the chipset to discern what kind of modem it is.
Dec 13, 2007 | RCA Cable Modem DCM315R (11603540)
Compaq was bought with msn companion service required
This is where you should be in contact with Comcast Tech Support 1-888 262-6300.
The INSTALL tech should have had you on-line before he left.
You need to conect your TV/Computer Cable to a Cable modem and a CAT 5 cable to your NIC (Network Interface Card)
All the lights on the modem should be on except the TEST light and the DATA light should be blinking.
You may have OLD drivers for the Cable modem, download those from another computer from the modem MFG.
Nothing else is required.
Dec 02, 2007 | Compaq iPAQ Home Internet Appliance IA-1...
Installation
If your internet or cable light is blinking then you probably have a cabling issue.These modems are designed to be ran with an RG6 home-run line to the cable box outside.You cannot have any splitters in between.A home-run is a cable that runs to the service box on the outside without any splitters.
Nov 03, 2007 | Arris SURFboard SB5120 Modem
Open Questions:
Computers & Internet Logo
69 people viewed this question
Ekse
Alun Cox
