Sandisk 16GB Cruzer with U3 download to iMac ???
I have a Sandisk Cruzer 16GB flash drive and I cannot get the security program to open in my iMac, so that I can download the content. It works fine on my Windows laptop.
Is there any way to get the the flash drive to work on my Apple desktop?
Thanks.
    Problem Solver:
  • 16 Answers
If the file is an .exe, then I recommend getting a wine based launcher such as Darwine. Try running it in Darwine, Wine or a similar program, if that doesn't work, then try formatting it to FAT32 (usable by both Windows and Mac [But you can't transfer files over 4 Gigabytes in size if you need that] ) or NTFS (and downloading MacFuse and the NTFS / 3G plug-in to be able to read and write NTFs on Mac) and not using the programs that came with the Flash Drive.
Posted on May 03, 2010
Describe your 2GB Cruzer Micro USB Flash Drive (SDCZ62048A10) Hard Drive Problem my cruzer data loss
For SanDisk flash drive to save the data, use software, U3 Launchpad. This program is used to saved data, repair damaged firmware, and firmware updates.
If you use the operating system
Win XP, download the software from here SanDisk Support
Win 7, download the software from here SanDisk Support
Hope it helps
Sep 17, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 8gb drive with u3 installed How can I
  1. Run the launchpad program.
  2. Double click on the icon to open up the main windows.
  3. Click on Settings and the U3 Launchpad Settings.
  4. Click on Uninstall tab on the side and then Uninstall U3 Launchpad. Before you do this, make sure all the programs on the flash have been closed and all the explorer windows are closed, too.
After uninstallation, the drive has only one partition. The pesky ready only partition with U3 program is gone.
Dec 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Dear Team Today when i try to use my CRUZER U3 (8GB) I GET MESSAGE "you have reached the maximum number of failed password...
Each U3 smart drive comes with a pre-defined number of login attempts. When you have only 3 attempts remaining, you will receive a warning message to prevent losing your data unnecessarily.
SanDisk does not have any method to bypass the password security feature on Cruzer U3 flash drives. SanDisk has not built in any back door or password reset methods. If the password feature is enabled and you exceed the number of incorrect password attempts, the drive will lock. Once the drive is locked there is no way to unlock the drive or gain access to the data stored on the device. You can only select the format feature, which will perform a secure erase (drive wipe) and data recovery will NOT be possible. U3 Cruzer flash drives which are password protected use 128bit AES encryption for data security
http://kb.sandisk.com/app/answers/detail/a_id/191
Sep 23, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
When I plug my new SanDisk 2GB Cruzer USB 2.0 Flash Drive into my computer, it says the drive is read only- How can I fix this?
If this is the U3 SanDisk Cruzer....U3 drives present themselves as two devices. One of them appears as a read-only CD drive that contains all the **** programs and the other is the writeable USB stick part. It comes with two partitions on it, one for data, and the other called "U3 Partition" which is read-only.
Mar 02, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to download softwares to my sandisk u3 flashdrive
As you may know your U3 Smart drive has a small OS that allows you to run Your applications on another computer. This OS shows as a CD-ROM icon on which you click to execute the LaunchPad (TheOS) of the Cruzer. In addition to that you have the icon of a regular drive. (Usually the Drive letters are consecutive G and H for exemple.) When you safely remove one both are unmounted at the same time.
Once the LaunchPad has been executed, it installs an icon on the sys-tray. When clicked, that tray icon opens a pop Up window, giving a menu of the applications installed and which you can run on the host computer, but from your drive (U3 Smart Programs on the left) and on the right various menu options
  1. to explore the drive,
  2. configure the drive(settings),
  3. add programs (to download additional U3 programs),
  4. and enable security. etc.
So if you want to download additional U3 Programs to run from you drive you use the Add programs (option 3 in the list above)
However, if you just want to put regular files on the drive (pictures, text documents, etc.) you do as you woul for nay drive: You drag and drop the files, not on the CD-ROM icon, but on the other drive. You can also use the Explore option (option 1 in the list above) to open the second drive to see what is in it, add files, remove files etc.
Hope it helps
Nov 10, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Problem with launchpad sandisk cruzer micro 16Gb mem stick (u3)
Start at the beginning. Look at how you entered your password and retrace your steps.
Jul 05, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer program no longer on flash after viruses were removed
New ones avail:
  1. Microsoft and SanDisk team up on U3 replacement - Engadget Microsoft and SanDisk team up on U3 replacement .... is actually pretty good, but they charge you extra to be able to install any program not on their list. ...
    www.engadget.com/2007/05/11/microsoft-and-sandisk-team-up-on-u3-replacement/ - 99k - Cached - Similar pages
  2. GnU3zer U3 LaunchPad replacement (download torrent) - TPB Oct 28, 2006 ... GnU3zer U3 LaunchPad replacement ... The windows CD autorun function can execute ANY program specified in the autorun.inf file provided it ...
    thepiratebay.org/torrent/3547144/GnU3zer_U3_LaunchPad_replacement - 16k - Cached - Similar pages
  3. Microsoft, SanDisk to Replace U3 Drives Microsoft and SanDisk on Friday announced a technology-sharing agreement that will produce a replacement for SanDisk's U3 line of USB smart drives by the ...
    www.physorg.com/news98193946.html - 55k - Cached - Similar pages
  4. Microsoft and SanDisk still working on StartKey - the new U3 ... Mar 7, 2008 ... Microsoft and SanDisk still working on StartKey - the new U3 replacement ... Microsoft and SanDisk Expanding on and Replacing U3 Smart ...
    www.u3-info.com/sandisk/microsoft_and_sandisk_still_working_on_startkey_the_new_u3_replacement - 13k - Cached - Similar pages
Jan 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
