Question about Sharp Heating & Cooling
Sharp AF-S125FX air conditionaer doesn't work when I plug it in
My Sharp air conditioner AF-S125FX doesn't work when I plug it in, even though a lamp works in the same outlet and we have had the same air conditioner on the same outlet for years. I push in the reset button, then plug the cord it, but the reset button pops out immediately.
  • 674 Answers
Sounds like there is something grounded inside the A/C unit or a fan or the compressor locked up. Could also be a motor winding in the compressor or one of the fans shorted thru.
Posted on May 02, 2010
Sharp af s125fx overheats and trips circuit breaker.
yes you can wash out fins on codensor. turn off power at breaker wash and let it set a hour before turning back on
Aug 07, 2015 | Sharp Heating & Cooling
My sharp comfort touch air conditioning 12,000 BTU FS-S125FX-A does not cool any more. It's running but at room temp.
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
Aug 07, 2011 | Sharp Comfort Touch AF-R120EX Air...
We need a replacement filter for our Sharp Air Conditioner Model AF - S60DX.
Karen, even though your model has been discontinued, you can still get a washable filter replacement for you AC Unit. Most hardware stores and home improvement stores sell a washable, mesh filter kit, that can be cut to size to fit your unit and hundreds of others. You'll probably have enough left over to make two filters, if necessary
I hope this helped you and thanks for choosing FixYa.
Aug 01, 2011 | Sharp AF-S60DX Air Conditioner
Sharp AF-M808X air conditioner. suddenly there is only fan air movement. there is no longer any cooling; turning the thermostat knob to a higher level doesn't "kick in" the coolant. but...
Simple test: the thermostat in your unit is electromechanical - unplug the unit from the mains, take it out and measure the resistance between the 2 electrical contacts, if it doesn't goes to near 0 when you turn it even a little bit then it's defective and it will have to be replaced.
If the resistance does indeed goes to near 0 then the defect is in the AC system. Another simple test: open the casing of the unit and put your hand directly on the compressor; now turn the thermostat button. If it doesn't vibrate then the starting capacitor of the compressor has failed and it will have to be replaced with a similar one.If it vibrates then the cooling circuit has got a leak and all the fluid has been lost. For that you will have to call a pro that will solder the leak shut and refill the circuit with the appropriate fluid - only he will have it, it's not sold on the customer market.
Jul 22, 2011 | Sharp AF-M808X Air Conditioner
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
I have a Sharp model number AF-S125FX that shuts off and I get the E1 message . I have cleaned the filter and tried the E 1 solution that was listed for a differant model number and have had no...
please check the relay of the comppressor and also the capacitor of the compressor. Check also if there is any issues in the controller section that can bring in the errors.
open and tigten all connectors, take a test on relays to manually switch on fan and compressor to confirm their worrking. the check for the micro controller's functiioning.
Sep 02, 2010 | Sharp Comfort Touch AF-R120EX Air...
My unit shut off now displays E1.
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Jun 05, 2010 | Sharp AF-S120FX Air Conditioner
Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Aug 02, 2007 | Sharp AF-S120FX Air Conditioner
Heating & Cooling Logo
335 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
