Question about Sony XPLOD CDX-GT200 CD Player
Got power to cd but no display - Sony XPLOD CDX-GT200 CD Player
  • 3 Answers
It sounds like you dont have the stereo wired in correctly...you will have 2x +12v inputs on the rear of the stereo.1 red and 1 yellow.the yellow wire supply's power to the illumination part of the stereos internals.and the red wire supplies +12v power to the rest of the stereo.so if you just have the red wire connected, you will have all functions powered except the illumination, so hence like you describe, your unit powers up and seems to work but no backlit display or buttons that should light up dont...I hope this helps? Just check you have both the yellow and red wires connected.it is also possible to have both the red and yellow from the dash to connect just to the yellow on the rear of the stereo to create a permanant live. So you can still have the stereo on even if the vehicle is turned off and keys not in the ignition...happy motoring!
Posted on Jul 14, 2014
  • 443 Answers
One idea that comes to mind is,if I remmeber correctly, that model has a removeable faceplate, try this, remove the faceplate,take some denatured alcohol on a Q-tip,clean the electric contacts on the back of the faceplate and also on the front of the deck where they mate together repeatedly for about 4 to 6 times letting them dry between each time that you swab them clean, then replace the faceplate onto the deck being sure that you are seatting the faceplate completely and properly.
This has worked for me sometimes and sometimes not, its worth a try.
Good Luck !
Posted on May 02, 2010
No display plays cd
seems there is a problem with your displays power feed or the display itself is down. let check voltage first by service
Aug 26, 2013 | Tascam Cd-rw900sl Cd Recorder/player
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Jul 07, 2009 | Sony DVP-S330 DVD Player
Xerox Fiery Xp12 - Problem (INVALID LICENCE) apears on the screen
You will need to use what came with your machine.
The note from Xerox states this.
NOTE: You will need the Fiery Restore / Update Server Software CD and the User Documentation v2.0 CD that came with your EX12 v2.0 Software
And here is the loading process
  1. Visually check to make sure the Fiery LCD is at the Idle screen before you proceed. This will make sure the Fiery is not in use.
  2. Insert the Fiery Restore / Update Server Software CD into the Fiery EX12.
  3. Press [Menu] button on the Fiery Server.
  4. Press the [Down arrow] button.
  5. Press the [Shut Down] button.
  6. Press the [Reboot System] button. The message 'Rebooting System' will display and disappear after a few moments. The Fiery Server will reboot and complete internal testing. The Restore / Update CD menu will be displayed.
    NOTE: Ignore the message 'It's now safe to power off the system'.
  7. Press the [Up arrow] or [Down arrow] button to scroll to 'Restore System' so this is highlighted. Press the [OK] button. The 'All data will be Deleted. Continue?' message will be displayed.
  8. Press the [Up arrow] or [Down arrow] button to scroll to 'Yes' so this is highlighted. Press the [OK] button. The 'Restoring System...' message will be displayed.
    NOTE: The System Restore will take approximately 7 minutes, during this time the message 'Restoring System...' will continue to be displayed.
  9. Press the [OK] button when the 'Restore Complete!' message is displayed.
  10. Press the [Up arrow] or [Down arrow] button to scroll to 'Exit' so this is highlighted. Press the [OK] button.
  11. Remove Fiery Restore / Update Server Software CD from the EX12.
  12. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
    NOTE: Wait 10 seconds before powering ON.
  13. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  14. The EX12 will prompt you to insert the User Documentation CD. Insert the CD and the Fiery will continue with the process. When the process is complete, the Fiery LCD will display the message 'Please remove CD'.
  15. Remove the User Documentation CD
  16. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
  17. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  18. Using the Configuration Report as reference, re-enter the network settings on the EX12.
  19. Install any required patches, as needed. Refer to the Updated Information section on the Configuration Report.
  20. If needed, restore any data that you previously archived. See the Related Items.
Jan 10, 2008 | Xerox DocuColor 12 Printer
New install of msi mainboard, no display on monitar or cd rom work
reinstall ur motherboard and cheak properly that ur mbo dont touch with earthing ( cheak ur power supply proper earthing )
Jan 05, 2008 | Intel Motherboard
DENON UD M50 CD PLAYER no longer works
Maybe you accidentally break some contact(s), on display or somewhere else. If that is the problem, soldering iron should solve that. Look for any loosen wires or detached contacts.
Oct 10, 2007 | Audio Players & Recorders
Philips display went out when power outage occurred
I can supply a replacement display from a scrapped unit, I'm in the UK, search on ebay for seller fluffcat1 and contact me.
Oct 04, 2007 | Philips CDR775 2-Disc CD Recorder
Pioneer cdx fm653 6 disk changer won't power up
first try to get another display, maybe it's broken (could be the cable cutted), the changer with a motor noise in the moment you plug it, tell me that its ok (95%).
Sep 12, 2007 | Pioneer CDX-FM653 6-Disc CD Changer
CD PLAYER
IT MAY BE- IF YOU CAN OPEN IT THEN SEE WEATHER THE COMNNECTION CABELS TO DISPLAY ARE PROPER.IF THEY ARE THEN THE PROBLEM LIES WITH THE POWER SUPPLY TO DISPLAY.
Mar 20, 2007 | Teac PD-H503 3-Disc CD Changer
Sony XPLOD CDX-GT200 CD Player Logo
434 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
