Screen won't advance after entered password
Have the white Pro. Put laptop in travel bag while moving over weekend. When I turn the laptop on and enter my password, the screen does not take me to the main page, but rather to a blue screen. The computer was not dropped or had any hard impact. Is there a way to re-set or solution?
Thanks a lot!
Adam
    Guru:
  • 377 Answers
Hi dear
open your back panel, where is the memory module (RAM) put in.
release
and reconnect again
oke
cropp
Posted on Mar 26, 2008
Entered password. Why did it turn off?
You put in the wrong password,power laptop down and when first comes up hit f2 and go into bios and change or delete bios password.
Sep 25, 2015 | Computers & Internet
Hpw to reset macbook pro
  1. Turn off your Mac (if it isn't already off).
  2. Hold down these four keys right after you press the power button: command+option+P+R (that will reset the PRAM).
  3. Keep holding down those four buttons until your Mac restarts and you hear the second startup chime.
May 28, 2014 | Computers & Internet
Black screen blue box saying
some one must have put in a boot password to your laptop,
follow this:
When booting up, enter your BIOS setup (usually by pressing the F2 key at the appropriate time).
Locate the BIOS Password section and turn the ON STARTUP password to off. There is no standard setup for BIOS, so I can't give you exact instructions.
If this does not work, try:
remove cell & start your pc you will here beep...beep...beep...
then turn off your pc & restore your cell.Start your pc and
password is removed.
there is a battery on motherboard,a button cell,you can try removing that and start computer, then put it back, bios settings will be lost.
you can also try removing any hardware like ram,if you have two,when system is off,turn on , it will prompt for changes , enter bios and try remove password.
Dec 15, 2013 | Gateway LT2001u Netbook
I forgot my password
Forgetting your User password is both annoying and easily fixable.
Turn laptop on and repeatedly hit F8 till a black screen with white writing appears with multiple options for you to select.
Highlight "Safe mode with command prompt" after a few minutes another screen will appear with the following.
C:/ Yourcomputersname/Your user name>
type "net user" press enter
type "net user Your user account name * "
(( Your User Name should appear under neath the "net user" command.
Type "net user Your user name *
It will ask you to enter a password, enter any password you like. Note the cursor will not move to show it recognised a key press this is for security purposes so please dont make a mistake.
It will ask you to re enter the same password
Re enter password then press enter
COMMAND COMPLETED SUCCESSFULLY should appear.
Reboot laptop and sign in with original User Name and new password you typed in above.
Nov 30, 2013 | Sony VAIO VGN-B100B Notebook
Password reset
if you dont know the password for the laptop well follow these steps.
  1. Power on or restart your Mac.
  2. At the chime (or grey screen if your chime is turned off), hold down Command+S on your keyboard to enter single-user mode.
  3. This step is optional, but it's a good idea because it checks the consistency of the hard disk before moving on. At the prompt, type fsck -fy and press Enter/Return. Wait for the checks to complete before going to the next step.
  4. Type mount -uw / and press Enter.
  5. Type launchctl load /System/Library/LaunchDaemons/com.apple.DirectoryServices.plist and press Enter.
  6. Type ls /Users and press Enter. This lists all of the usernames on the computer - helpful if you don't know or remember what these are.
  7. Type dscl . -passwd /Users/username password and replace "username" with one of the users displayed in the previous step. Replace "password" with a new password of your choice. Press Enter.
  8. Type reboot and press Enter.
Apr 23, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
How do i reset my toshiba satellite pro S300?
does the enter password come up before or after windows starts?
Mar 18, 2013 | Toshiba Satellite Pro L300 Notebook
Presario cq62 white screen
It sounds like there is a loose connection to the screen from the motherboard. As the motherboard gets warm it expands, which could be enough to break the circuit to the screen and cause the issues you are having. If so, the case will need to be opened and the connection checked and tightened. It may also be an inverter issue, this converts DC power to AC power and may be failing, not supplying enough power to run the screen.
Mar 05, 2012 | Compaq Presario CQ62238DX Laptop
My pipe trades pro when solving a rolling offset only gives me 0.0 degrees
Hi jlight49,
Your Pipe Trades Pro calculator from Calculated Industries comes with FREE technical support:
Live chat - http://messenger.providesupport.com/messenger/calculated.html?ps_s=PJ2Ks9f4GXh8
Email - techsup@calculated.com
Phone - 1-800-854-8075
It is hard to tell from the description of your issue, but when working with a rolling offset, the [Angle] will show 0.00. All the rolling offset outputs are accessed through the second function of [Travel] which is labeled as [Roll].
The key sequence is:
-enter your rise into [Offset]
-enter your advance into [Run]
-enter your roll into [Roll] by pressing [Conv] [Travel]
-press [Travel] repeatedly to see the rolling offset outputs, starting with Length, followed by Fitting Degree, etc.
Contact technical support and they will help you out!
Thanks.
Sep 15, 2010 | Calculated Industries Pipe Trades Pro 4095...
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
