Question about Bugaboo Cameleon Jogger
Front right wheel broke on part that locks wheel into shaft. can i just buy a replacement wheel and fix it myself?
  • 3 Answers
If it is just the wheel broken and the frame is not damaged it is easy enough to get a new wheel and insert it yourself.
Posted on May 26, 2010
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
Front wheels not turning in 4wheel drive 1996 dodge dakota
Check and make sure the transfer case is adjusted right If the front end was broke you would know it. Jack up one front wheel and put it in 4wheel drive but not lock and see if the front drive shaft turns if it doesn't you need to adjust linkage or if it's electric make sure the signal is getting to the transfer case. If it only locks front and rear jack up one rear wheel also and do the check. Most people with 4 wheel drive don't know they have two wheel drive One in the rear and one in the front unless you ordered a locking dif from the factory they don't come this way. Then you would have 3 wheel drive
Dec 02, 2011 | 1996 Dodge Dakota
Last week my drive shaft broke on my99 expedition 5.4 with4x4 so I replaced it then my rear end started lockin up so I replaced it now my reear wheels roll then lock up,roll then lock up, any ideas?
u need to raise the wheels off the ground an disconnect the drive shaft an spin the wheels by hand u may have a bad posi unit. the stress of breaking the shaft may have caused this
Jul 12, 2011 | 1999 Ford Expedition
Just wondering if i can tow a ford f-150 with 4 wheel drive and with the front tire off the ground or also known as a car dolly or will it damage my truck????? also wondering about my power steering pump...
1. If you disconnect the transmission , no.
2. Either your steering shaft - relatively cheap and easy to replace - or the steering box - expensive and hard to replace - are at fault. How was your luck lately?
Nov 19, 2009 | 1988 Ford F 150
When I accelerate it feels like the brakes are being applied.
sounds like your emergancy cable is out of adj!!!!!
Apr 13, 2009 | 1995 Chevrolet K1500
1990 toyota 4runner 4x4 wont lock in front wheels
your drive shaft thats turning is mabe broke or your automatic 4x4 lockers could be bad
Feb 24, 2009 | 1990 Toyota 4Runner
97 blazer 4x4
Had an issue similar to this with a customer astro van. It was the front differential that destroyed itself. We took the front driveshaft off and he drove it like that for a while. Then sold it. So, I am not sure what happened inside that front axle, but is was locked up. As long as we took off the driveshaft, the spider gears were the only thing spinning internally. So it could be driven again.
Dec 26, 2017 | 1997 Chevrolet Blazer
Can't remove motor from dryer
you need to pretty much disassemble the whole machine. the top cover comes off, the front panel with door comes off. the drum lifts out to access the motor as it is bolted to the floor.
Nov 29, 2007 | Whirlpool LEQ9858P Electric Dryer
Broken casters (wheels)
This is definitely something that you can do yourself. Remove the back of the dishwasher and the front kickplate. This will give you access to the wheels. The wheels are held in place with a U shaped clip. Remove the clip and the wheel will come out. replace with the new wheel.
This happened with my Danby DDW1805 and I fixed it myself. I used two step stools at the side of the dishwasher to raise it off of the floor.
Aug 28, 2006 | Danby DDW1805W Designer Series...
Bugaboo Cameleon Jogger Logo
222 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
