Question about Code-Alarm Code Alarm Transponder
Alarm keeps going off on ford transit R-plate need to turn it off as driving neighbours mad and need to drive 2moro at 5 but cant drive with alarm going.had this prob with escort van but could turn alarm off with crook lock key , but cant find where to with this van ,also the fob does not work so cant turn off with it ,have been driving van for ages with no probs so cant understand why its suddenly going off need to know where to turn off or dissable alarm untill i can get it to garage on wed cheers for help
5 Suggested Answers
  • 250 Answers
SOURCE: ford transit2.5 td 99v immobiliser probs wont start
back of fuel pump, take apart and run a wire straight from ignition to solenoid,
if stuck get back 2 me
Posted on Aug 19, 2009
  • 4905 Answers
SOURCE: Central locking not working
Assuming that the battery mentioned above is the Key Fob battery?
The usual solution to the key fob not working the Central Locking after battery replacent  is to remove the car battery feed fuse   to the Central Locking (or disconnect the car battery )  for 10 minutes...replace it..... then it should work OK
note: If you disconnect the Car Battery then make sure you have the radio security code.
If not then POST A NEW QUESTION quoting your radio Serial Number (usually begins with M * * * *  * * )
Posted on Sep 25, 2009
  • 37 Answers
SOURCE: Alarm in a 2004 Ford Escape
Not a complete solution but something to try .Using the key lock and unlock the vehicle from the drivers door .Some models in UK have an arm switch on the lock barrel in the door which sticks.
Posted on Nov 14, 2009
SOURCE: ford transit on 06 plate alarm just goes off when
see if it has a glass breakage sensor.
If it has it may need to be adjusted. Arm your alarm and tape on your windows or put your mobile phone in the cab and call it. see if your alarm goes off
Posted on Jul 18, 2010
Hi i drive a 03 ford transit when you press the clutch pedal it feels fine but you cant select gears only 5 gear when you try to get first gear its like the clutch is not being pressed
Your clutch disc may be worn out, when the disc wears completely down the pressure plate goes over center and that causes the clutch to slightly engage when the pedal is depressed and you grind gears, most clutches last about 75000 miles.
Oct 20, 2016 | Ford Cars & Trucks
Alarm wont turn off
use the key and lock and re lock the car 4 or 5 times on the passenger door.
Jan 17, 2014 | Ford Mondeo Cars & Trucks
My alarm keeps going off bmw 316ti
Yes, it could be the door switches.If the door switches aren't on the B pillar, then they are within the door lock mechanism and you will have to remove the inner door skin to get to them.
Nov 14, 2012 | 2004 BMW 316ti Compact
My Toyota Camry 2001 XLE alarm keeps going off. Door sensor not working properly. How do I disable alarm system so my neighbours can sleep.
I had the same problem today - called Toyota dealer and they said to turn on the ignition, press the red button (alarm indicator), then turn off ignition, turn ignition back on, and it should be set to off. I am going to try this evening to see if it actually works. Also, he said if you don't have the button on the dash to look near the kick plate for a toggle switch and follow the instructions the same.
Aug 25, 2010 | 2001 Toyota Camry
Ford transit on 06 plate alarm just goes off when it feels like, check doors all sound can u help.
Jul 04, 2010 | Code-Alarm Code Alarm Transponder
I don't show this car as having an alarm, but if your battery is discharging everyday without driving it there is a problem somewhere else, tis is not normal and should still be under warranty
Jan 30, 2010 | Code-Alarm Code Alarm Transponder
I cant figure why it alarms every morning 5 am
dodgy neighbour ?? or neighbour going to work and his vehicle is giving off an ultrasonic sound??disconnect the alarm is the easiest way
Oct 17, 2009 | 2004 Mitsubishi Outlander
Alarm warning sound bit no warning light on dash board, cmax
It maybe the seatbelt connection fault as some fords don't all have an illumination on dashboard
Jul 03, 2009 | 2004 Ford Focus
Cannot disable anti theft alarm driving neighbours mad
There should be a relay under the hood for the security system, if you can not find it, try jacking the front of the car up, it should have a sensor that tells it that it is being towed and should turn off, unless of course it has a bad wire that is grounding out.
Dec 14, 2008 | 2008 Mercedes-Benz Mercedes Benz C Class
Code-Alarm Code Alarm  Transponder Logo
133 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
