Computer will start but no signal to the moniter
  • dnnshinson May 02, 2010
    i had to many programs open while i was installing zone alarm and when i went to reboot it never came back up.the cpu is running but all i get is a no signal detected.its a hp windws vista, 2 years old
  • MyPC Solutions
    MyPC Solutions May 11, 2010
    When you turn your computer on, are you at least able to see the Bootup screens?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
There are a few things you can try to fix your problem.
Step 1. Turn off your computer.
Step 2. Disconnect your monitor's video cable from your monitor if possible and the reconnect it.
Step 3. Disconnect your monitor's cable from your computer's graphic adapter, reattach it.
Step 4. Reboot your computer and see if you have video. if you do, problem solved, if not continue with step 5.
Step 5. Reboot your computer and press F8 during bootup, this will take you to Safe Mode. (this is assuming that your monitor is working correctly during the bootup process, if not, you may have a bad video card)
Step 6. When prompted, select Safe Mode (wihout networking).
Step 7. Safe mode will only install the basic drivers and software.
Step 8. After successful login to your machine, reboot the machine and let it boot up on its own.
Posted on May 02, 2010
  • 186 Answers
Vga cable or check to see if monitor is pluged in check outlet may be bad '
My emachines tower flashes green and not send a signal to moniter
can you give more info if there is any sounds comming from the tower
Apr 08, 2012 | E-Machines eMachines Desktop PC
No signal on computer moniter
1. Check your cable
2. check your cable pins make sure there not bent.
3. Check your video card make sure its putting out the correct resolution for the monitor.
No signal is just what it is. You may have a bad cable,bent pin or video card is not operational.
Things you can try.
Hook it up to a diffrent computer
Check the pins on the cable.
Worse case would be the little board inside where the connector is could be bad.
Thanks I hope this helps
Dec 07, 2009 | Acer AL1715 17" LCD Monitor
My computer says no signal
Check you rmnitor data cable from CPU its not connected
Oct 05, 2009 | E-Machines eMachines W2686 PC Desktop
My computer often fails to start. even if the hard disk is running my moniter and keyboard doesn't show ant sign of power signal and the moniter screen just remain blank with power led of moniter blinking
Note: make sure that the computer is turned off before removing the RAM from the DIMM slot. Hope this helps.
Sep 27, 2009 | MSI 845 PRO Motherboard
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
Moniter says no signal
You may need to replace the moniter cord or check the video card on the computer.
May 31, 2009 | Acer Aspire™ T180 PC Desktop
Hanspree monitor says,''No signal input check video cable''
ask the shop for a replacement cable. it could be broken.
Mar 26, 2009 | Computers & Internet
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
VGA
open it up and look for defective capacitors on the video input board and replace them. Should probably replace the 470uf caps on the power board while you are in there.
Jul 29, 2008 | Gateway FPD2185W 21 in. LCD Television
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Computers & Internet Logo
David Payne
David Payne
