Question about Microsoft Xbox 360 Console
I plug my xbox 360 on and it dosnt even turn on
  • 186 Answers
Recheck all your connections '
Posted on May 02, 2010
Xbox wont turn on i just finished downloading halo wars and a few miniutes later it shut off
hey a :-)
is ur power brick 'green/orange/red light on ??
if it is firstly make sure its fully pushed into ur 360 ! (i know.....im sure u tried this already)
It could be RED' ?? but it dosnt really matter.....its still the same fix !
assuming you have some sort of power to the power brick (any colour)
un plug it (from the mains).......
im gonna guess you have been using some sort of USB connection (either a controller charger, wired controller or usb stick)(music ect ect)....either to the 2 front usb slots or the 1 at the back.......??
if this is the case un-plug EVERYTHING from all used usb slots........
now try powering up the 360 .......??
If it still dosnt power up (assuming you have some light on the power brick??) revert to plan 'B'.....
un-plug the power brick from the mains again.....& unplug 'ALL' connected leads from the 360 so you just have the 360 with nothing plugged in ! if you have a torch ect have a look inside all usb slots you have used (for charging ur controller ect even the back one if u have used it ??)
inside all used usb slots are little 'prongs' ...if in the process of plugging in & out chargers/wired controllers ect you accidently bend one of these prongs & it touches the sides of the casing surrounding the usb slot it shorts the board out & results in 'No power up' of the xbox ! its a simple problem to fix yet difficult to spot unless ur told about it !
usually un-plugging all usb used slots rectifys the problem but failing that check inside them for bent prongs !
I find a pair of tweezers or a tiny screwdriver does the job best :-)
plug power lead back in & try again
let me know how u get on ??
hope this helps ??
Feb 13, 2010 | Microsoft Xbox 360 Console
Xbox 360
Hi
Did you already updated your xbox 360 with the newest firmware?
Jan 09, 2008 | Microsoft Xbox 360 Console
So i have a green xbox 360 controller and a white one. My wireless headset will sync with my green one but when I try to use it with my white one, it is recognized as player two and not syncing with the...
hi there,
just a quicky...but ur wireless headset dosnt sync to the controller it syncs to the xbox :-)
it dosnt matter which controller you use its synced with the xbox & not the controller !
if ur using 2 different controllers depending on which you switch on first will take player 1 as will the wireless headset. if after you have switched it on (the xbox) you decide to use the other controller it will obviousley take player 2 slot (even if you switch the other controller off first) as will the headset !
hope this helps :-)
Feb 13, 2010 | Microsoft Wireless Headset for Xbox 360
Turtlebeach x4 problems
Make sure you're using new, factory-fresh, fully charged batteries. If that doesn't help, you'll probably be best off contacting Turtle Beach tech support at support@turtlebeach.com.
Jan 27, 2010 | Microsoft Turtle Beach X4 Dolby Digital...
Red light on power box for 360
i have to personally dissagree with 'wildbear' :-)
well not actually dissagree but i think the problem will be at lot less technical than all the writing he has done.
a simpler check.......does the 360 'switch on' ??
i assume with a red light on the power brick it dosnt ??
the problem is more likely a faulty pin (terminal) inside one of the USB slots you have been using for either a controller charger or wired controller (or a usb memory stick to play music thru ur xbox??)......plugging chargers/wired controllers in & out of either the 2 front slots (behind the flap) or the 1 at the back can sumtimes bend one of the terminals causing it to touch the outer casing of the usb slot ?? if it does this it shorts the board of the 360 which in turn stops u powering up the 360 all together :-(
one of the signs of this is a 'RED' light on the power brick & the 360 not powering up at all !! but sumtimes the power brick light will stay orange or even green.....even with this fault ! it dosnt always turn red !
One way to rectify it is (un-plug the powere brick from the mains first) & unplug ALL USB CONNECTIONS TO THE 360 !! (controller chargers ect) & try powering up the 360 !! (after plugging it back in)
if this fails ur gonna need a torch & a little screw driver (or tweezers) un-plug everything from the 360 & look inside ALL usb slots you have used ! check to see if any of the prongs have bent accidently whilst plugging in & out chargers ect ..... if they have straighten them so they are not touching any of the sides of the usb slot....
after doing this ...plug back in and 'hopefully' Whoooop Whooooop :-)
hope this helps ??
failing this it maybe as wildbear suggests & its a problem with the power brick altho i very much doubt it ?? they normally way out live an xbox !
remember thumbs up if this helps :-)
Jan 01, 2010 | Microsoft Xbox 360 Console
My xbox 360 controller won't connnect or get power
try plugging it into another slot and blow on the end of it if that dosnt work i dont know what else u can do
Dec 25, 2009 | Microsoft Xbox 360 Controller
Just got play and charge kit and i put the rechargeable battrey pack in and pluged it in but now the controller and console are not reading snigle
sometimes the xbox has a syncing problem, then controller when turned on turns on the console, so it is obv working but dosnt connect after that, i had this problem and what i did was as followed, 1. turn the console on dont use the controller hold the sync button on the Console for 30 seconds, after this turn off the console and remore the power plug from the console and your mains, now wait about 5 miutes, then plug it up, first click the xbox sync button, and hold the remotes sync, this should then work. if not i suggest contacting microsoft, http://www.xbox.com/support
Jun 07, 2009 | Microsoft Xbox 360 Wireless Controller
360 powerblock works when not pluged but dosnt when is plugged
It is the power brick. If you are under warranty you can have microsoft send you a new one for free, otherwise a new powerbrick is around 80 dollars.
Feb 06, 2009 | Microsoft Xbox 360 Console
Xbox 360 wireless controller
Could be one of three things
1) the controller had been used on a different console, in which case push the little button on the console right below the memory slots then try reconnecting.
2) if that fails, turn the console off, un plug it, plug it back in then turn it on and try to connect
if that dosnt work thn repeat number one but this time also push the little white button on the top of the controller looke like this (((  O
Dec 01, 2008 | Microsoft Xbox 360 Console
Xbox 360 CONTROLLER QUESTION
Are you syncing them up? To do this press the small white button on top of the controller at the same time you press the small circle button on the front of the console.
Jul 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
