Question about Compaq X09 Gaming (DE410031934163) PC Desktop
X09 - no video
I have a Compaq X09. beginning yesterday the machine turns on but no video. tested the monitor with another device and monitor is fine. keyboard doesnt seem to work either as nothing happens if I push the num lock or cap lock keys (light on keybourd does not turn on/off)
  • tabarre May 02, 2010
    thanks, i will check those two issues out
  • 666 Answers
Well first make sure you have a working keyboard hooked up otherwise your computer is not going to want to boot at all if your still having issues booting up check the graphics card and make sure it is seeded in its slot properly if it is you may need a new one
hope this helped
Robb
Posted on May 02, 2010
Compaq presario sr5030nx no video
compaq presario sr5030nx: This a Desktop? If so,Is the monitor plugged in, turned on, working, test with another machine, check the cabling from monitor to tower, unplug and inspect for bent pins. first. Now , when you say ,"compaq presario sr5030nx no video" and "black screen", do you mean your video player is not playing?
Nov 10, 2012 | Computers & Internet
I have a COMPAQ CQ60-420US NB PC. Last few months some webpages would 'jiggle', I chalked it up to slow servers. However... yesterday the screen went white. I turned on the laptop, the drive and...
I would plug it into external monitor. it if works good on the monitor. could be bad video cable or lcd panel. video cables get pinched in the hinge or lcd get broken due to lack of support around the screen (poor design)
Jun 20, 2017 | Compaq Presario CQ60-204NR Notebook
I have an hp pavilion dv5. When I power it on the computer starts up but the monitor doesn't come on. And then it does this series of beeps. Beep beep beep. It does that series 5 times
Before you begin
Check the following items before using the steps in this document:
•If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
•Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
•If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
•Disconnect all connected devices except the mouse, keyboard and monitor. This includes thumb drives and camera-type memory cards from card reader slots.
With the devices disconnected, restart the computer. If the computer starts and the monitor now displays a picture, a device is preventing the computer from starting. Update the BIOS to resolve this issue.
Step 1: Connect the computer to another monitor
Connect another monitor to the computer to determine which device has the problem (the monitor or the computer). This step is very important to help you determine if the problem is coming from the computer or the monitor. If necessary, temporarily connect the computer to a friends monitor for troubleshooting purposes.
After the monitor is connected, turn on the computer and the monitor. What happens?
•If the newly attached monitor does not display anything , disconnect the cable and continue at Step 2: Is the video connection damaged?
•If the newly attached monitor displays the first startup screen(s) but then goes black, there is a problem with Windows starting. Skip to step 5 .
•If the new monitor works , the original monitor or its cables are faulty. Do the following:
1.Replace the monitor power cable.
1.Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
1.Replace the video cable.
1.If the monitor does not work after replacing the cables, replace or service the monitor.
Inspect the video cable and video connectors for damage. Check for sharp bends or breaks in the cable and bent or broken pins at the connectors. With the monitor and computer off, try to straighten bent pins with a small metal tube, like the tip of an empty mechanical pencil or the tip of a retracted pen.
Figure 1: Video connector
If you had to straighten any pins, reconnect the monitor making sure that the video cable is firmly connected and then turn on the computer and monitor. If the display is still blank, continue to the next step.
Step 3: Resetting and updating the BIOS
You can use these steps even though you will not be able to see anything on the monitor.
In case an item was changed in the BIOS, such as the primary display device setting, use the following steps to reset the BIOS back to its default configuration:
1.Turn on the computer and repeatedly press one of the following keyboard keys. Press the key about once every second for 5 seconds after turning the computer on.
◦For HP and Compaq computers that came with Windows 7 and Vista, press F10 .
◦For HP and Compaq computers that came with Windows XP, press F1 .
◦For Compaq Presario desktop computers built prior to 2002, press F10 .
1.Wait another 5 seconds.
1.Press the F5 key. This restores the default settings of the BIOS.
1.Press the Enter key. This accepts the changes.
1.Press the F10 key. This saves the changes.
1.Press the Enter key. This saves the changes and exits from the BIOS.
1.The monitor should display the first screens received from the computer (the logo screens). If not, find and download the latest BIOS update if one is available for your computer.
1.If a BIOS update was not available or the monitor is still blank, continue to the next step.
Jun 11, 2010 | Computers & Internet
Will not display windows XP from a Compaq tower with a Sempron 3500 cpu. Is the vidio card on the cpu too powerful for the monitor?
If the monitor has power, and is turned on, there should be a display. Have you checked your video driver? Do you have another monitor you can connect your computer to? If so, go to My Computer, right click, on the menu click on properties.
The look for the hardware tab and click on device manager. See if any of the devices are showing a trouble icon, especially the monitor and video areas.
You can download your video driver from the compaq support website if you need an updated driver.
Apr 08, 2010 | Compaq MV 500 Monitor
My Girlfriends Compaq Presario sr1920nx has lots of problems... the one right now is the display. I replaced her monitor with another used one because it died. Now the one I just put on won't stay on, you...
Please check your cable, video settings, video card drivers and your monitor settings.
Also test the monitors on another computer. If they turn on while connected on another computer then your problem is your video card on your problem computer, that's if all else fails. This would mean that you would need to replace your video card.
So let's begin. It's obvious checking your video cable is pretty easy.
Ensure that both ends of the video cable are plugged in nice and tight and secure. Usually this video cable is blue at the ends.
Check your Video Card Driver
Go to your device manager in Windows.
Nagivate to Control Panels/System/Hardware Device Manager in Windows XP.
In Windows Vista and 7, Navigate to Control Panels, System, Device Manager
Look in Monitor and see if there is a yellow question mark or exclamation mark. If there are then right click on them and update the driver. Also while you're in here, go ahead and make sure there are no yellow question marks or exclamation marks. IF there are then go ahead and right click and update the drivers. You will need internet access for this. Follow the prompts to completion.
Let me know if this solves your problem.
Don't forget to give me a good rating and vote for me.
Mar 24, 2010 | HP Compaq Presario SR1920NX PC Desktop
I switched it on and begins to flicker and even with noise
1)Restore Monitor to factory settings using Menu buttons.
2)Perform Monitor self test
Turn the monitor off and disconnect the video cable from the computer. Turn the monitor back on.
If self test is displayed on screen without any issues, Monitor works fine
OR
Monitor gone bad
Jan 10, 2010 | Dell 828FI 15" CRT Monitor
Copaq x09 - drive light and power light are on, but nothing else happens- no sound no video- nothing
well its a gaming computer. meaning that is was custom build. it could be that your sound and graphic card are not secured in place. take off the side pannel and do this.
Sep 25, 2009 | Compaq X09 Gaming (DE410031934163) PC...
CRT Monitor Stuck In Stand-By
So the monitor is not bad try to disable the video card from bios if possible and firstly remove all external devices (USB's) and gets the safemode meny and select vga mode and disablem the video drivers and uninstall and reinstall the drivers
Jul 01, 2009 | Compaq MV 540 15" CRT Monitor
No image
This monitor series( HP Compaq WF1907) seem to have a inherent problem with the sleep mode control circuit. You should take this unit into the service center for repair. Hope this helps.
Apr 01, 2009 | HP Compaq WF1907 Monitor
Hi, I have a compaq deskpro that is working fine however, the monitor is having trouble. I took the monitor to the shop and it is fine also. Likewise, I placed a monitor from another computer onto the...
The monitor setting in windows maybe incorrect. When booting up before you get the windows logo start hitting F8 and then choose safe mode. If your monitor works in windows there then check the monitors settings. You may have a driver issue or a settings issue when in normal windows mode.
Jul 07, 2008 | Compaq Computers & Internet
Compaq X09 Gaming (DE410031934163) PC Desktop Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
