Question about Moen 1 Handle Lever Shower Faucet With POSI Valve NI
Only warm water from the tub/shower
I had a new moen single handle shower/tub put in with a new tub and now i get get hot water from the shower. i have a new hot water heater which was checked. i get hot water in the sink and the kitchen, but the shower water was 8-10 degrees cooler. i took off the safety stop so the handle can turn wide open but no change. i have heard of the mixing valve?
    Top Expert:
  • 12,804 Answers
Their are safety settings from factory --anti scalding remove handle and cover you will see a blue ring and a red ring adjust the rings for the temp you want
Posted on Aug 09, 2015
  • 349 Answers
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
Posted on May 03, 2010
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
When i turn it on it is only warm at best. when i turn it all the way hot the water comes out in a trickle. all our other showers and sinks get hot water just fine. this is a single handle shower and does...
You will need to remove the old cartridge from inside the shower valve body and either refurbish it with new rubber seals and O rings or replace the cartridge altogether (preferable). It's not a complicated fix but the Posi Temp cartridge can be a bear to remove. Moen and Danco make special 'pullers' to make the cartridge removal go a little easier (sold at Lowes/HD and plumbing supply for anywhere between $15 and $35 but well worth it, IMO).
Oct 27, 2010 | Moen & Posi-Temp Single Handle Shower Or...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Waters hot instead of cold when you turn it on
You have to remove cartridge and rotate 180 degrees then re-install. Was it removed or replace lately?
Jan 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I have a new moen single handle shower faucet that is only giving one temp of water (cold). Only if I have it on very slow will I feel hot water. Any idea how to fix
Did the hot water shut off get turned back on fully after the change? Is the hot water line kinked under the sink? Is the hot water shut off valve working?
Aug 05, 2009 | Moen & One Handle Tub & Shower Faucet
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen 1 Handle Lever Shower Faucet With POSI Valve NI Logo
786 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
