Question about MSI P6NGM-FD Core 2 Quad Socket 775 1333MHz PC2-6400 Motherboard Retail
No sound from front headphones
On board audio is Realtek ALC880 HD audio and no matter what configuration i use I can't get sound out of the front case phone jack. I've downloaded all the updated drivers I could fine, went over the board connections several times, disabled the "jack detection" as sugested at some boards. The jack worked fine with my MSI 865 PE Neo 3 with AC`97 that I replaced so i know it should work.
Also the front usb ports work but interesting enough the additional back usb bracket aren't functioning.
  • Lisavisa Mar 26, 2008
    The speaker is good, no problems there..everything is in correct slot & plugs per instructions. I think this advice to check the amps etc may very well lead to the answer and will have my brother( who's better with power issues than I ) check it out when i bring the PC to him in a few days.
    I'm am still open to other suggestions we can try as well.' Thanks,
    Lisavisa
  • Anonymous Jun 12, 2008
    no sound from front sockets
Check your speaker is good and it i inerted in the correct slot and it raise the error of POST so the mother board power had some problem cheak wether the led in the mother board glows properly once it correct check with your board input power +-5,using your multimeter.or else there is a problem in your smps
Posted on Mar 26, 2008
No sound on HP 1140n desktop computer NO audio
enable the o board sound card from bios
Mar 23, 2011 | HP Computers & Internet
I have an intex headphone, I have installed the realtek drivers and the headphone was working fine but I format the c drive and install windows again the same one windows xp sp3 and now after I installed...
*********** board installed sigmatel audio is being a original which supports system configuration. you cannot configure or change. So try to use sigmatel headphone.
Feb 25, 2011 | Computers & Internet
I am using a Dell optiplex 320 here i use headphones for communicating with my friends since last few days i notice that i could hear my voice through my ear piece. Pls kindly assist me immediately.
This is called and Echo, if you can get Realtek drivers or if already installed you will need to configure them not to produce this echo or at least minimize it. Click on the Speaker icon on the lower right hand of your monitor this will allow you to configure your Realtek HD Audio software. ebiau.jpgClick on sound manager ......on the Menu's click on the Microphone and select Noise Suppression this will do the magic.
May 13, 2010 | Dell (8H390) Sound Card
The ECS A770M-A onboard REALtek audio problem
if everything is up to date, softwares, and other related issues you had mentioned...seems like the audio amplifier in your pc is not functioning or it had been damamged...alc880 high definition audio driver, try to uininstall it, and if you had tried any other related alc drivers to install..remove it from the system and re-install it..if it works..no problem, if it dosnt..try to play your media player, if you are able to see graphics moving...then your audio amp is damaged..check out
Oct 14, 2009 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
No audio device detected
hi not sure what is the full model name for your m/board but you can try to reinstall the sound driver again using the correct driver from the orginal manufacturer foxconn.. you can get the driver from below link...
http://etech.maiila.com/foxconn-rc4107ma-drivers-and-specification
hope this helps...
good luck
Apr 01, 2009 | Foxconn Computers & Internet
Can't hear audio
I found many references to this issue but I am not sure which may apply to your problem. Here is a set of steps to follow from another site: (Assumes Vista and Realtek)
  • Open Vista’s Control Panel (Window | Control Panel)
  • Open the Realtek Audio Manager (not “Sound”)
  • In the navigation bar in the far right, there is a little yellow folder icon. It is just below “Device advanced settings” and above “ANALOG”. Click the folder icon.
  • Click “Disable front panel jack detection” so that a yellow check mark shows up. Hit “OK”, and close the Realtek HD Audio Manager. That should re-enable the sound
Mar 30, 2009 | Microsoft Windows? Vista Home Premium...
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
Realtek HDA driver
The driver you are installing needs more requirements. try to install driver from mother board CD. If not try to download realtek HD driver compatible to your processor.
Aug 28, 2008 | Microsoft Windows XP Home Edition
MSI P6NGM-FD Core 2 Quad Socket 775 1333MHz PC2-6400 Motherboard Retail Logo
166 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
