Question about Dell Inspiron 1525 Notebook
One side of the the screen has popped out of the piece that connects it to the base
    Scholar:
  • 63 Answers
Now your hinge has broken. It can be replaced. Go to any laptop serice centres, order them new hinges for your laptop model. But it will definitely cost you some money.
Posted on May 02, 2010
Favorite thing dropped into the seat belt cavity in the back seat of a 2006 Lexus LS430. Any good ideas? Through the trunk or how do we remove the back seat?
Pop the rear seat base out. Just push against the seat base bottom on the sides of front of seat bottom with your knee and pull up with your fingers. Seat base will come up no problem. Retrieve your "favorite" thing and put the base back in, hold it down with your hands while pushing it towards the rear with your knee and it will pop over the holding clips. Ya got your piece back and no harm done.
Jul 20, 2017 | Lexus Cars & Trucks
Quick Prep fell and popped into two pieces. I have the key match for the two haves but am unable to get the slots from the mixer end to slide into then male ends on the base end. Is there a way to...
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Make sure you line up the drive pieces and the logo goes on the side with the switch.Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
Nov 29, 2010 | Cuisinart CSB-33 Quick Prep Handheld...
Looking to replace speakers and don't know how to take apart
browse to the internet for motorola razor v3 dismantling
Oct 11, 2010 | Motorola Mobility RAZR V3
My connection is bad on my portable ipod docking station. goes in and out... has something to do with the little piece in the base. help.
Where the Ipod sits in the dock, there's a removable piece that you can pop out....that should take care of your problem.
Mar 13, 2010 | Bose SoundDock digital music system...
Installation.
Get under the sink inside the cabinet to do this. First, take loose and remove the connection of the arm that goes into the drain tail piece. It is on the back side of the drain piece and connects to the rod that you pull up on the faucet when you close the drain. Next, loosen and remove the nut on the back side of the drain tail piece that holds the drain lever in place. When you remove this, it will allow the old pop up plug to be removed. You put the new pop up plug in by reversing the proceedure. Make sure the rod gets inserted into the new drain pop up and the nut is snug enough to make a water tight seal when you reassemble it. Reconnect the pull rod and you are done.
Oct 12, 2009 | Moen 103459 Drain Pop-UP Plug
Need to change electrical cord on g5 kirby
This should be fairly easy to do. With the cord unplugged, take the screw out that it holding the hard plastic cord cover onto the base of the machine. This is where the cord looks like it's going into the bottom of the machine. The next part is a bit tricky. The hard plastic piece holding the cord in can be popped out with a flat head screw driver. On each side of the cover pop the tip of the screw driver into the side and gently pull to the side. Do this on both sides of the cover and it should come right off.
The cord should just pull out.
Put the new cord in, pop the plastic cover back on, and put the screw back in.
Let me know if you need more help.
Aug 19, 2009 | Kirby G5 Bagged Upright Vacuum
Release spring popped off when dumping the cannister.
As long as the black piece still has the "nubs" on both sides at the turn in the "L" shape and the base isn't broke then this is going to be easy. There is a groove on the main unit the little wheel fits into that groove, the "nubs" fit into small holes on the swivel down piece, and the spring fits between the small side of the "L" shape and the bottom of the swivel down piece.
Apr 16, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I need to take the back off a navman s70
Im surprised noone has answered this considering navmans track record for producing waste products. I say this,as i have 5 sat useless,due to being 2nd owner,so uncovered by warranty,in some cases,units being less than 1yr old,so i have had a look myself. Ok. Here goes. hold the unit screen towards sky,base facing you. You will see 2 screws,one either side. These hold the side covers in position. Remove these,and if you have strong nails,insert finger nail between side cover and back,start at bottom and pop the bottom lug then the top. It should be held the same on other side of side cover. repeat this on other side of unit. The side covers should now be off and exposing back cover side edges now. Take your finger nail and insert between back cover and base at one corner,it should pop open slightly,repeat on opposite corner. This is from memory. your cover should now lift off. Try the screen ribbon where it joins the board for connection first,there is a tiny black lift up ribbon lock to lift up then make sure ribbon is pushed firmly home,maybe even clean the connectors. The rest is in your hands if this does not work. Good luck.
Jan 21, 2009 | Car Audio & Video
Saturn LS1 2000 - driver side window locked down unable to close.
It's the switch.
Put your fingers into the leather shifter boot at the base and feel under the rim to pop the outside ring that holds the faux wood trim at the base of the boot up and out. (The piece is faux wood on an LS2, it may just be colored plastic on an LS1) You may need to do this twice, on each side of the boot, so that the entire piece of trim and the boot pops up and out. The leather boot should still be connected to the trim, it will pop out as a unit.
Once it is out, you can reach into the housing and feel the window switch unit from inside the housing. There is a spring clip on the upper and lower ends of the switch unit, press in the spring clip and pop it up one end at a time. The unit is now out but still attached to the power. I have never unclipped the wire harness but it looks easily doable.
IF YOU ARE REMOVING THIS BECAUSE THE SWITCH IS STICKY you probably DON'T need a new switch - you can spray some contact cleaner in the ports at the side of the unit and underneath the switch, this will probably fix your problem, at least if you have ever spilled a soda anywhere near the switch.
Dec 20, 2008 | 2000 Saturn SL
AOC lm929 monitor
AOC LM929 or Envision EN-7100 removal instructions:
DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
with a small flat head screwdriver, insert into the edge and pop open the small plastic
pieces that surround where the stand connects to the monitor. put plastic pieces aside.
lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
remove 4 screws in the center that hold on the stand. put stand and screws aside.
lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
side edge of the grey plastic and turn screw driver so the plastic surrounding the
screen edge pops up exposing an area surrounding the screen. put plastic rectangle
piece aside.
slide out plastic buttons piece from the side and put aside.
with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
the screen assembly to the back housing. now lift screen assembly out of the plastic
housing. put back plastic housing and screws aside AND lay the monitor screen with the
FRONT side down on a flat soft surface.
with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
cover. slide the cover down and remove. put the cover and screws aside.
USE CAUTION!!! Some components may still contain a charge.
check fuse... whatever...
Aug 29, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
110 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
