Question about Frigidaire FMV156DC Microwave Oven
Frigidaire FMV156DCC light stays on
Frigidaire FMV156DCC (over-range-oven model) light over-range (buttom-side of microwave) stays stuck on.
5 Suggested Answers
  • 52 Answers
SOURCE: How do I replace the door on a Frigidaire
TIP: Go to the web and type partselect.com enter your model number then scroll down to your part. Click to enlarge exploded diagram on left and you will be able to view at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 28, 2009
SOURCE: Microwave light bulb out
This is simple, and "FixYa" technical staff has clearly not looked at our model.
Take off the vent across the top (three long screws) to expose a single screw over the keypad.
Remove the single screw, and the whole keypad consile will lift up and off, likely hanging by a plastic tab/support on the bottom.
Now you can twist the light bulb plug to remove it from the support structure, change the bulb, and replace all that you've done.
Simple.
Posted on Jul 13, 2009
  • 414 Answers
SOURCE: frigidaire microwave fmv156dcc the
Many of the newer microwaves are fused in the cooking portion of the unit. There is usually
A ceramic automotive style fuse in a holder inside the case of the microwave. Be sure
to unplug unit before attempting to replace this item (about 2 dollars at an appliance
parts store or even radio shack). The volts and amps are stamped on each end, normally
250V (250 volts) and 5A (5 amps) Be aware that the capacitors can hold quite a
residual charge similar to an electric fence, so be mindful of them.
(can shaped items with leads coming to them usually metal). Hope this helps.
Posted on Apr 26, 2011
joeguest2
  • 2080 Answers
SOURCE: Need a user manual for
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137230en.pdf
And here is a link to the wiring diagram for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/5995451720.pdf
And here is a link to the installation instructions:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137233en.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 25, 2011
FMV156DCC stopped working.
It may be a blown fuse or thermal cutout / thermostat on either the magnetron or oven cavity.
We have the basic FMV156 service manual and have uploaded it here to help you.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes. Then you can access most of it for testing and part replacement.
May 26, 2011 | Frigidaire Microwave Microwave Oven
Microwave just stopped cooking!
The simplies is the fuse, which is located inside the unit, you need a screwdriver to open it
Aug 18, 2009 | Frigidaire FMV156DC Microwave Oven
Changed one of the door switches on my microwave now no power
check the green ground ground cable on the control panel
Aug 05, 2009 | Frigidaire FMV156DC Microwave Oven
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
124 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
