Question about John Deere Tractor Turbo Charger 6200 6200l 6300 6300l ()
The clutch will not engage on my 6410 john deere it will sometimes if you pump the clutch peddle about a milloin times. i took the valve out and cleaned it and it did not help one bit. it worked fine before i took the priority valve out and replaced it. the other hydralics on the tractor work perfect they are good and strong its just the clutch. any help you could give me would be great thank you.
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: Problem with plowing with my john deer 4440 tractor
check you air cleaner and fuel filters if they are dirty it will rob horsepower
Posted on Jun 05, 2009
mickey813
  • 472 Answers
SOURCE: John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Posted on Oct 15, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
F525. Updated mower switch by John Deere is not engaging mower
The John Deere F525, a front cutting machine, has 3 fuses.
20 Amp
15 Amp
10 Amp
Check the 15 amp fuse. I believe this supports the PTO clutch. If you replace the fuse and it blows again, check the electric clutch. You will likely find burnt or melted wires. The bearings do go out on these clutches causing them to run hot and eventually burn up.
PTO Clutch will not engage: There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
Resistance 3.7 ohms
Current Draw 3.25 amps
It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
Cap Screw torque 55 lb-ft (75 N.m).
If the fuse blows, I recommend you check the resistance of the clutch. If the clutch is shorting to ground it will show zero resistance when you ohms the connector wire to a ground position. In which case, you will have to replace the clutch.
Fixing Electric Clutches
Other possibilities.
On the F525 there is a cut-off switch in the hydraulic system. It is a low pressure cut off. If you were running the mower and deck and then it suddenly stopped, it may be low pressure in the hydraulics. It will not automatically reset as you are using the same volume for the drive pumps. Once the oil gets low enough it cuts out the deck drive 1st, then the drive pumps.
Apr 16, 2015 | John Deere Garden
John deere lt160
bad check valve take to shop 150.00 for check valve
Sep 07, 2014 | Garden
Need to fix UJ joint on John Deere 6410 between clutch and quad range
well ph it's your choice either the engines gotta move forward or the rears gotta go back , lucky it's only gotta move 10 inches as the shaft is splined so it'll slide off
personally Id move the rear ooh and your gonna need a overhead gantry or crane to do it rated for 5 tons at least
Feb 19, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
Have a 6410 4 wheel drive After tractor set over
You need to install a check valve in the line to prevent the fuel from leaking back into the tank creating an air bubble had the same problem.
Dec 08, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
I have a john deere K series 17hp riding mower. when I try to engage the blade the safety mechanism works but the blade will not engage. the switch has been replaced.
Hi, sounds like the clutch. If you feel confident you can strip the mechanism down, clean and replace, otherwise its a new clutch.
Aug 29, 2010 | John Deere Garden
John deere gt 235 electric blade engagment but mower dies when you try to engage
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Mar 20, 2010 | John Deere Garden
John deere 997 z trak pto not working,changed pto switch not help
You may have a defective park brake switch or the pto clutch could need to be adjusted.Does the machine **** down when you try to engage the pto?If so also check the seat switch.To adjust the pto clutch you need a 9/16' wrench and tur all three lock nuts on the clutch a half turn at a time a retry the clutch,keep going until it will stay engaged.
Nov 08, 2009 | Garden
John Deere Tractor Turbo Charger 6200 6200l 6300 6300l () Logo
194 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
