Question about Sony HDR-FX1000 Mini DV Camcorder
My fx 1000 powers down after 45 seconds and then back up on its own after another 50 seconds to 1 min. It will do this consistantly over and over. Tryed different batteries and power supply. tried different tape. same results.
  • 321 Answers
-it's look like thats is the dc/dc converter
...hope that give you an idea
Posted on May 02, 2010
How can i convert decimal in degrees, minutes and second
I don't think I have that calculator, but let's work through it with any calculator.
Let's say our heading is 45.3275 degrees. So we know it is 45 degrees, so subtract 45 from the number and multiply by 60, since there are 60 minutes in a degree. I get 19.65. So now we have 45 degrees and 19 minutes. Subtract the 19 minutes to calculate the number of seconds by multiplying the result by 60. I get 39 seconds. Overall, we have 45 degrees, 19 minutes, and 39 seconds.
Good luck.
Paul
Apr 22, 2015 | Casio FX-65 Calculator
How do I program a transponder key for the ignition in a 2009 Pontiac Vibe?
first the first digit must start with the number 1,or 4 of your 17 digit number for this to work.so fit your chip key in your ignition.
1, insert the key in your ignition turn the key to on for 10 min 30 seconds
2, within 45 seconds turn the key to off then back on for 10 min 30 seconds
3, within 45 seconds turn the key to off ,then back on for 10 min 30 seconds then back on for 10 min 30 seconds.
then after 10 min 30 seconds turn off then on .then start the engine.
Dec 17, 2014 | 2009 Pontiac Vibe
Meter to kilometer
There are 1000 meters in a kilometer and 3600 seconds in an hour (60 seconds per minute, 60 minutes per hour).
Press 8 0 0 / 5 0 * 3 6 0 0 / 1 0 0 0 =
or 8 0 0 / 1 0 0 0 * 3 6 0 0 / 5 0 =
The result should be 57.6 kph.
Nov 11, 2011 | Casio FX-115ES Scientific Calculator
Black screen open
hi
First of all if you can remove the ram memory DO IT SO ifyou cant try without removing FIRST.
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILLSTART ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK ANDCONTUNUE TO USE YOUR LAPTOP
May 26, 2011 | HP Mini 1000 Netbook
Black screen
hi
-remove battery pack(if you can remove memory ram as well) and wait 10 mins
-unplug the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DON'T PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILLSTART ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK AND CONTINUE TO USE YOUR LAPTOP
Nov 02, 2010 | HP Compaq nc6400 Notebook
TV turns on/off automatically at 1-2 mins intervals.
Replace the power supply, PN: BN44-00206A
It's easy to locate, but requires adjustments once it is installed. Panel voltages must be adjusted according the the specifications of the TV. There is a sticker on the back of the plasma panel which provides each voltage setting. You can reference this sticker to make the proper adjustment. Using a DMM, connected between chassis ground and the panel voltage you are adjusting, turn the adjustments on the power supply very slowly, until you are measuring the specified voltage within 0.5v. I hope this helps and good luck.
Mar 15, 2010 | Samsung PN50A400 50 in. HDTV Plasma TV
I hv a colemanpowermate 5000/6250w generator- won't stay running
Hi, Please understand that this type of troubleshooting is hard without seeing it but doesn't sound like a fuel issue at all. This genset does have other sensors that will shut it down like low oil and high temperature. Most likely oil from your description. You also don't say what load it is carrying, could you be plugged into something that cycles off and on and when it cycles on the genset shuts down from the overload? If you think this might be the case, disconnect everything and power up a few at a time especially things that cycle on and off like refrigerators, heaters, stoves. Good Luck!
Jan 30, 2009 | Coleman Powermate Premium Plus 6250W...
Sub power comes on consistently for about a second and thuds
u might have bridged the amp below is ohm load, if that the case run the speakers in series instead of parraell !
Dec 25, 2008 | Kenwood KAC-9152D Car Audio Amplifier
No manuel, do not know how to work
Hi Journeay,
The dehumidifier is telling you the humidity in your house is 45-50 % so it will not run until the dehum thinks it is over 60%. When you set a humidity it will show the setting then it will tell you the humidity in the house. Sometimes they are wrong, and somtimes the humidistat goes bad. I would suggest setting the dehumidifier lower than the 45-50 and see if it comes on. This time of year the humidity is usually low depending on your location. I have already put mine away for the winter. Please let me know if you have any other questions and I really hope this will fixYa. If not just let me know.
Mike
Sep 30, 2008 | Haier 45-Pint Dehumidifier
Sony HDR-FX1000 Mini DV Camcorder Logo
71 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
