Question about Goodman CKL30AR30 Air Conditioner
Condenser fan motor not coming on - Goodman CKL30AR30 Air Conditioner
  • 674 Answers
If the compressor is running your problem will most likely be the capacitor for the fan. If the capacitor looks like it has expanded that's a good sign it is bad. Some units have a 2 pole capacitor that runs the fan and compressor and it is possible for 1 side to be bad. Your fan motor could also be the problem. Try to spin it by hand and see if it rotates freely. If you have a multimeter check the fan windings resistance. You can also use a meter to check the cap. if it has that function.
Posted on May 02, 2010
Rheem air conditioner fan comes on ,goes off ,comes on but not all of the time reaches room temp then goes off
If your description is in a few minutes, It sounds like a loose wire. If it is the outside fan motor to which you were referring, it should have 3 wires. Find those 3 wires and trace them back to the control board and main contactor. check the condition of any connections and the condition of the insulation. Next, If it is the blower motor, do the same thing.
It also sounds like it could be the control wiring. The blower control wire is the green wire coming from the thermostat and going to the fan control board in the air handler. If you have a loose connnection in the thermostat and/or loose connnection for some splice in that wire, it could interrupt the control power to the blower motor and cause it to cycle.
If it is the condensing fan on the condensing unit, it is the yellow wire. Check the same criteria as green wire above.
As far as the last of your inquiry, the air conditioner reaches temperature then turns off is normal and is not part of the problem your having.
The only other thing I can think of without more information, If the condensing unit comes on and shortly later turns off, the question is whether the condensing fan comes on when the compressor turns on. I had a case today, both the outdoor fan and compressor would not run, but the main contactor was pulled in, and voltage was available. It turns out the dual capacitor was bad and the condensing fan had stopped running and the compressor was cycling on the inherent motor protection inside the compressor. Inside the compressor is a bimetallic overtemperature switch that helps protect the compressor from getting to hot. This is your probable cause and can be determined by checking the temperature of the condensing fan motor and the temperature of the compressor. If both are so hot your hand gets burned, you probably need an new capacitor and outdoor fan motor. If the compressor cools by turning it off, the inherent motor protection will reset if it has not burned out. If after deenergizing the compressor cool off and will not reset, the compressor will have to be changed.
Hope this helps.
Jun 25, 2014 | Goodman CLQ36AR49 Air Conditioner
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
Hi, my mistral (MPAC50 just started coming up with an error code E5. it wont go into airconditing mode and only uses the fan
E5 Outdoor activation of compressor over heatprotection or motor lock
Compressor overheated due to condenser block or fan motor lock. Clean condenser/replace out door fan capacitor.
Dec 30, 2010 | Heating & Cooling
I have a GE Profile GSL251FRF BS. For the past week a high pitched squeal/sqeak is heard when the motor is running. What is that and what's the fix?
This is likely one of the fan motors. If it is coming from the lower back it would be the condenser fan and if it is coming from the frezzer compartment it is the evaporator fan. Both are inexpensive and easy to check and replace. Here are a couple links that should help
Condenser fan replacement
Evaporator fan replacement
Dec 21, 2010 | GE Refrigerators
Kenmore model 3639550610. Ice maker motor and freezer fan motor wont stop. Need to find wiring diagram.
If fridge repair because it is noisy, turning off and on, or running all the time, it could be a sign the condenser fan motor is going bad. Thankfully, this type of repair is not as complicated as some may think. You can check the condenser fan motor yourself and replace it if necessary.
Tools and Materials Needed:
* Multitester
* Screwdriver
* Needlenose pliers
Step 1 - Disconnect the Power
Turn off the power to the refrigerator to prevent electric shock.
Step 2 - Remove the Condenser Fan Motor
The condenser fan motor is located on the bottom of the fridge, most likely toward the back. Heat from inside the fridge is released into the air here. A panel will probably need to be removed to access the motor. Depending on the screw, a screwdriver or nut driver will be required to remove the panel. Find the condenser fan and motor. You can quickly check the fan's operation by seeing if anything is obstructing its rotation. Manually move the fan blades to see if they spin freely. If they do not, you may need to replace the fan. Continue removing the condenser fan motor by taking out the screws that affix it to the mounting bracket.
Step 3 - Test the Condenser Motor
Your condenser fan motor will most likely have 3 wires attached. Some models have just 2. Note which wires are connected from the fan to the motor. Use needle-nose pliers to remove the wire connectors from the motor. Be careful not to damage the wires. After the connectors are removed, use the multitester to check the resistance or passage of electrical current. Set your multitester to ohms.
If the condenser motor has 3 terminals, only the outside terminals need to be checked. The inside one is a ground terminal. Check the terminals by using the multitester probes, touching one probe to one terminal and the other probe to the other terminal. The reading should fall between 0 and infinity. If you reading falls on either 0 or infinity, then the condenser motor is bad and will need to be replaced.
Step 4 - Replacing the Condenser Motor
Condenser fan motors can be ordered from the refrigerator's manufacturer. Once you receive the new motor, check it with your multimeter the same way as the old motor. This will make sure the new motor is in working condition. Attach the wire connectors to the new motor in the identical locations as the old one. You can refer to the new motor's wiring diagram (most likely included with it) if assistance is needed. Now install the new motor under the fridge. Attach it to the mounting bracket using the same screws as before.
Step 5 - Testing the New Motor and Keeping it Efficient
With the new motor connected and attached, turn the power back on. The unit should operate correctly. If it does not come on, check the wiring. Dust and dirt can plug a condenser and affect the fan's ability to discharge heat. Cleaning them several times a year will help the fridge run efficiently.
Hope this help in solving.take care....
Sep 18, 2010 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator makes naoise intermitently. Could it
Most cases it is coming from evaporator fan or condenser fan motors. 80% is coming from evaporator fan or condenser fan motor, 5% from compressor and 5% from flow of refrigerant ( gurgling ), 10% from the rest.
Mar 07, 2010 | Refrigerators
Fan motor will not come on
That thing connected to the capacitor is a booster for the compressor .But if the outside fan doesn't work , the compressor will shutt off on overload because the high pressure in the condenser coil.
First try to replace the capacitor in the condensing unit (it's the only one that works for the compressor and the fan motor) ,but if the fan doesn't start, you need to replace the fan motor.
Sep 14, 2009 | Ruud UBHC Air Conditioner
I have a RUUD Achiever 11 and the outside fan does not come on, and house won't cool. Was told I need a condenser unit. Perhaps I'm overly skeptical, but wouldn't replacing the fan be an easier (and less...
depends on the condition of the unit and if the condenser fan motor is the only problem?
whoever told you that you need a condenser he or she needs to tell you why and point out the issues with what you have seems to me.
to answer your question it would be yes to the fan motor vs.condenser
Jul 05, 2009 | Ruud UBHC Air Conditioner
CONDENSER FAN WHIRLPOOL MODEL CA3030VKA1 2 TOM
check the capacitor of the fan motor.fan motor wiring will be done in parellel to the compressor check the wiring.
May 31, 2009 | Whirlpool ACQ122XK Air Conditioner
Evaporator fan did not start running when condenser fan started.
I don't know why there would be much of a delay between the condenser and evaporator fans coming on. If you have diagnosed it as a bad motor, that's probably correct.
But the motor could just need cleaning and lubricating
Apr 28, 2009 | Kenmore Refrigerators
Goodman CKL30AR30 Air Conditioner Logo
697 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
