Question about Dometic Rooftop RV Air Conditioner
When set to cool and thermostat turned down all it does is blows hot air Duo-Therm model # 59146-331
  • 674 Answers
Check to make sure the compressor and condenser fan are working. If the are you may need to have the charged. If not you need to find out why.
Posted on May 02, 2010
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Duo Therm Quick Cool A/C fan motor cycles from low to high
sounds like the motor is either wired incoirrectly and getting 1/2 power all the time or it is going to ground. check out the woiring real good and duse your ohhm meter to check for gounds.
Dec 20, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic a/c, duotherm thermostat, turns right back on after it reaches desired temperture.
I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
May 13, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
230 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
