Question about Toro Lawn Mower With Toro Power Tools
Distinct white smoke coming muffler area, we
Distinct white smoke coming from muffler area, we changed the oil yesterday, and it's still happening today. Will it eventually stop, or should we stop using it and troubleshoot this issue? If so, any suggestions?
  • 198 Answers
I would drain the oil and re-check the amount you put back in.
Posted on May 04, 2010
White smoke coming from lawn mower
If it is coming from the general area of the mower, you've probably gotten some oil on the muffler. That might be from a spill (hopefully), in which case it will stop as soon as the oil burns off. Check for nearby components that might be loose and dripping oil on the muffler.
On the other hand, if it is coming OUT of the exhaust, that is a sign the motor is burning oil which could be caused by bad valve seals or worn piston rings. Both are repairable conditions. The question is how much do you want to invest in the mower?
Aug 29, 2014 | Toro Garden
99 Grand Am Smoke Exhaust
I'm sorry to say your engine may be cooked.
Since you are adding both oil and coolant, and the color of the smoke is gray or white, you have the signs of the engine burning coolant.
The common cause is a leaking head gasket.
Dec 17, 2012 | 1999 Pontiac Grand Am GT
I have white exaust smoke coming out, ive already replaced my head gaskets and im not losing any coolant. truck does try to die on me when im going up hills and such. i have a rear main seal oil leak but i...
You need to smell the white smoke. If it is still burning coolant, the smoke will smell sweet and it will dissapate fairly quickly. if it stays like a cloud and doesn't have a sweet smell then it is most likley oil. When you changed the head gaskets did you check the heads for flatness? When you say it's not losing any coolant, how are you checking? do you take the cap off the radiator or do you look at the overflow tank? It doesn't take much coolant leaking into the cylinders to make white smoke. I would do a pressure test of the cooling system.
Aug 21, 2011 | 1999 Chevrolet Silverado 1500
Bout a bike 2 day been out for a hr and noticed lots oil near the carb n airbox n its seems to be coming frm a pipe which is conected to the top of engine
check your oil level maybe it is more than full if it is good, check your muffler if there is white smoke coming out. if there white smoke coming from your muffler you have a problem in your piston rings, need to be change. thanks...
Apr 27, 2011 | KTM 250 EXC-F Motorcycles
I changed the oil and white smoke poured out of the exhaust. Also there was oil spewing all over.
Depending on if you laid the engine over on its' side, there could have been oil in the muffler. It may take some time to "burn" this off. It will also come from the muffler. Given enough time the oil will get hot and smoke off of the muffler. Then it will no longer smoke.
I hope this answers your question.
Apr 03, 2011 | Garden
Whenever I start the car it smokes than after warming up it stops smoking.
The key is how much smoke? Does the smoke have a smell to it. Are you consuming any fluids, like coolant, or oil?
Tons White smoke that is sweet smelling is usually coolant getting into the combustion chamber.
Less white smoke, especially if other cars are doing it, is normal. For every gallon of gas that you burn, you generate a gallon (GALLON) of water. so this water usually evaporates, but sometimes not. It has little or no smell.
If the smoke is bluish white, that is oil, but usually your converter would fill with oil, and cause error codes, or loss of power. This smell is distinct, but not necessarily sweet.... After the converter heats up, it may be able to burn off the oil and the smoke stops.
What are you consuming, fluid wise, will direct where you go next.
Jan 27, 2011 | 1995 Lexus LS 400
Polo TDI smoking
Yep! Blown head gasket.
Feb 02, 2010 | 2001 Volkswagen Jetta TDI
What does it mean when water is in the tail pipe smoke?
This is Usualy NORMAL as CONDENCATION Builds up Inside the EXHAUST System. Not to Worrie about this UNLESS it Has the DISTINCT ODOR of COOLANT
Nov 08, 2009 | 1995 Lincoln Mark VIII
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Smoke and electrical odor
Most likely some components in the power supply board burnt out. You may need to replace the board.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toro Lawn Mower With Toro Power Tools Logo
830 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
