Wa 612 Wireless Navigator utility
plz le mee know in detail , r u noot able to go into the interface of yor wless accesspoint,,,, or ya r not able to connect to the acces poing from yor wireless computer.
if you ar using an wless acces point then yor computer should also have a wirelless adapter/interface/card in most recent laptops its coming inbuilt.
lets assusme that ya have the wlees adapter/card/ interface on your computer but you are not able to connect wireleesly to yor access point--- thenya need to check wireless zero configuration (WZC)service of windows xp.(assuming that you r using xp or above)--steps to enabe WZC are -- START , RUN -TYPE "services.msc" without quotes, check the service from the bottom to top , ya will find wireless zero configuration , double click it n check startup type should be- automatic- and service staus should be-- running. click apply n ok , n if there are some wireless singals approaching to your this computer ,it will show ya a message like signal detected from your accesspoint. n ya ll be able to connect wirelessly ,,,,,,,,
+++++ note : if this doesnt work the do le mee know the details of the complete setup n default ips on acces point n your comps ip , wired one
or chat with with me online , i m online t ill 11- pm indian time thru samrat101@yahoo or same id on msn mesngr also.
take care .. samrat
