Question about Canon PIXMA MX310 All-In-One Printer
Canon MX310 print job is choppy
After replacing the ink cartridge in my Canon MX 310 it won't print properly. The text is choppy for lack of a better term, to better explain some of the top or bottom portion of the text is chopped and slightly moved to the left or right of the rest of the text.
Can't seem to find how to put ink into my canon mx 310 printer
I'm assuming when you said "fine catridge" you meant FINE cartridge. FINE is an acronym for the Canon Ink Cartridges. Anyhow, plug your printer into the electrical outlet and turn the power on. Wait about 1-3 minutes and open it up and the Ink Cartridge holders should move to the left for you to properly insert your Ink Cartridges.
Jan 31, 2013 | Office Equipment & Supplies
The canon 310 MX is not able to accept new ink cartridges error 6000
if you purchased a canon 310 mx and if it is new..contact the supplier about it.So that they can instruct you how to fix it..Good day
Dec 02, 2011 | Canon PIXMA MX310 All-In-One Printer
CANON MX 310 NO COLOR CARTRIDGE CAN i PRINT IN BLACK & WHITE
Hi there
No you will not be able to print just with back ink alone, the printer will not work it needs all the inks, sorry.
Take care all the best Pineworks
Mar 14, 2010 | Canon PIXMA MX310 All-In-One Printer
On my canon MX 310 printer I put in new Canon CL-41 Fine color cartridge and now the alarm light is lit and the screen says Check Ink U051 COL How can I correcty the problem?
You may need a new cartridge, that error says the ink cartridge is wrong or not installed properly. If it's a refilled cartridge it won't work, if it's a new canon cartridge, they warranty for 30 days from date of purchase.
Dec 23, 2009 | Canon PIXMA MX310 All-In-One Printer
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
MX 310 printer
Some "remanufactured" ink-cartridges are just "refilled" cartridges,
and the company that refills them cannot "reset" the electronics inside the ink-cartridge to report that the ink now is "full".
So, just use the cartridge until you notice that the ink has gone empty.
May 21, 2009 | Canon PIXMA MX310 All-In-One Printer
Replacing cartridges in canon pixma mx 310
Go to this page:
MX310 Support
Click on the "Support & Service" tab. In the "Search Our Knowledgebase" block, type in replace ink and click "Search".
There should be a link at #1 dealing with installing ink cartridges. Click on the link and it will show with pictures and animation how to remove and install them.
Thanks for using Fixya.
Mar 30, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx 310 alarm color cartridge empty
Go to the printer driver (control panel -> Printer -> Right Click your Printer -> Properties). From there go to maintenance tab, Ink Cartridges, Select Black only. Then click OK. Finally hold the Stop/ Reset button for 10 secs or so. It will then work after a couple of warnings.
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Reset mx 310
This really worked with my MX 310:  http://www.fixya.com/support/t378057-reset_ink_levels_canon_mx310
Jul 03, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
215 people viewed this question
old marine
old marine
