Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Moldy odor My washing machine has a terrible moldy smell. I have tried running bleach only loads, leaving the door open and not using the machine for a week. Nothing helps.
Try the cleaning compound they sell as this website:
It is fantastic! Works better than vinegar and bleach and really solves the problem!
Posted on May 05, 2008
  • 552 Answers
Try running it with just vinager and water no clothes.
Just put about a cup of vinager in it and wash cycle and another cup in rinse cycle.
Vinager is a better disinfectant and odor eliminator than bleach.
Posted on Mar 25, 2008
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
Moldy mildew smell won't go away.
When I get the mildew smell , I run the machine empty and only use bleach. Then when done leave the door open to dry out. Works every time.
Oct 23, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
There is a moldy smell....I have ran a load with no clothes and just bleach and it smelled ok for a week and now smells again
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub/basket, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 24, 2009 | GE WSXH208A Front Load Washer
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smelling washing machine.....
Hi, did you wipe out the inside of the boot with the bleach? This is a big problem with all front load machines. If you call the Whirlpool, I believe they have a product out now to help the odor as well.
May 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell
try running it throgh a cycle with nothing but hot water and bleach let set for a couple of minutes between cycles with water in it may have to do a couple of times
Mar 29, 2009 | Whirlpool LSB6200KQ Top Load Washer
Washing machine odor this product has been devoeloped to lessen front loader odors. you NEED to be using an HE detergent. low sudsing ans specifically design for use with front loading washers.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in front load kenmore washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
322 people viewed this question
Sal De
 Brian Main
Brian Main
