Question about Xerox Phaser 6200N Laser Printer
Set factory default
I have a phaser 6200 and want to set factory default...how do i do that?
Go to the menu, look in setting and scroll through until you see factory default setting. The functionality you're looking for should be in this area.
Posted on May 02, 2010
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
How set factory default xerox 7800
Solution : Reset the Printer to the Factory Defaults (Reset NVRAM) WARNING: Only use the tool when directed to by Xerox Service. All user and system settings will be lost.
  1. Select [Printer] on the Touch Screen.
  2. Select the [Tools] tab.
  3. Select [Setup].
  4. Select [Service Tools].
  5. Select [Reset NVRAM]. A confirmation screen will be displayed.
  6. Select [Reset NVRAM] again.
Related Knowledge Bases:
Mar 05, 2014 | Xerox Printer Division Xerox Phaser...
How to reset Xerox Phaser 3100 to factory settings?
First you have to enable the admin mode:
press and release: (down arrow) * #
on SOS1 change the 8th bit to 1 (counting right to left)
ie: 00100001 to 10100001 {press OK to confirm}
Now the admin menus are enabled.
To <Erase all. Reset to default configuration>
press (and release): (down arrow) #7
Feb 19, 2013 | Xerox Phaser 3100MFP
Xerox phaser 3600 factory reset
If you're locked out of the NVRAM reset from the control panel, you can still try performing a network reset by going to the Network menu and selecting Clear Setting. After rebooting, you should be able to get in through the administrative web interface at http:// using the default username of admin and password 1111
Aug 22, 2012 | Office Equipment & Supplies
Reset to factory settings xerox phaser 3250
Reset to factory settings xerox phaser 3250 - Fixya
www.fixya.com/.../t12176778-reset_factory_settings_xerox_phaser_325...
Mar 26, 2012 - A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without ...
Mar 26, 2012 | Xerox Office Equipment & Supplies
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Mar 03, 2010 | Xerox Phaser 4500 Printer
Phaser 7700 prints slow
You have to clear the memory.. once you clear out the memory then it will work properly again. What this does it loads up the factory settings.
1. From the Main Menu, highlight Support and press OK.
2. Highlight Service Tools Menu and press OK.
3. Reset NVRAM is displayed, press OK.
4. Highlight Reset NVRAM and Reset Printer NOW and press OK to reset all
the settings to default.
Sep 28, 2009 | Xerox Phaser 7750DN Laser Printer
Advice phaser 7300dn appear 10: eeprom ,help me please!
The only thing you can do is attempt a reboot and hope for the best, otherwise call out an engineer to repair it! Or you could try and NVRAM reset but I'm not sure if that will work and be careful because you will set the machine to factory settings and may have to do a colour calibration all over again. Let me know how it goes.
Resetting all settings to default (NVRAM)
Resetting the NVRAM will reset all printer values including network, printer setup, job defaults, and color calibrations.
  1. Press the Down arrow key and scroll to Support.
  2. Press the OK key.
  3. Press the Down arrow key and scroll to Service Tools Menu.
  4. Press the OK key.
  5. Reset NVRAM will be displayed.
  6. Press the OK key.
  7. Reset NVRAM and Reset Printer NOW will be displayed.
  8. Press the OK key to reset all the settings to default.
Dec 11, 2008 | Xerox Phaser 7300DN Laser Printer
I have a Phaser 8400 printer that needs to be repaired. Where are your authorized service stations in my area (Miami, FL 33142)?
Here you go
clear.gif UNITED DATA TECHNOLOGIES INC
8825 NW 21ST TERRACE
DORAL, FL 33172
Phone: 305-882-0435
Fax: 305-882-0436
Products Serviced: Phaser 8200, Phaser 860
clear.gif MONARCH ELECTRONICS INC
SUITE 319
1440 79TH STREET CAUSEWAY
NORTH BAY VILLAGE, FL 33141
Phone: 305-866-1885
Fax: 305-865-8087
Products Serviced: Phaser 6120, Phaser 8400, Phaser 8500, Phaser 8550, Phaser 8560, WorkCentre C2424
depot_logo_small.gif IT SOLUTIONS
7210 NW 58TH ST
MIAMI, FL 33166
Phone: 305-513-0059
Fax: 305-513-0062
Products Serviced: DocuPrint 4508, DocuPrint N2025, DocuPrint N2825, FaxCentre F110, Phaser 3150, Phaser 3400, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 740, Phaser 7400, Phaser 750, Phaser 780, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8550, WorkCentre C2424, WorkCentre PRO 423, WorkCentre PRO 423/428, WorkCentre PRO 428
clear.gif LASER PRINTER SOLUTION / FIX A FAX CORP
7240 NW 31 STREET
MIAMI, FL 33122
Phone: 305-471-0093
Fax: 305-471-0113
Products Serviced: Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 840, Phaser 8400, Phaser 8500, Phaser 8550, WorkCentre PE120, WorkCentre PE120I
clear.gif P M E INC
SUITE 130
10800 NW 21ST STREET
MIAMI, FL 33172
Phone: 305-994-9222
Fax: 305-994-9922
Products Serviced: CopyCentre C20, DocuColor 2006, DocuPrint 4508, DocuPrint 4512/4512N, DocuPrint N17, DocuPrint N2025, DocuPrint N2125, DocuPrint N24, DocuPrint N24/N32, DocuPrint N2825, DocuPrint N32, DocuPrint N3225, DocuPrint N40, DocuPrint N4025, DocuPrint N4525, DocuPrint P1202, DocuPrint P1210, FaxCentre F110, FaxCentre F116, N2025/N2825, N2125, N3225/N4025, N4525, N4525, Phaser 1235, Phaser 2135, Phaser 3150, Phaser 3200MFP, Phaser 3400, Phaser 3450, Phaser 3500, Phaser 4400, Phaser 4500, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6100, Phaser 6120, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 7300, Phaser 740, Phaser 7400, Phaser 750, Phaser 7700, Phaser 7750, Phaser 7760, Phaser 780, Phaser 790, Phaser 8200, Phaser 840, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8510/8560MFP, Phaser 8550, Phaser 8560, Phaser 8560MFP, Phaser 860, WorkCentre C2424, WorkCentre M20, WorkCentre M20I, WorkCentre PE120, WorkCentre PE120I, WorkCentre PE16, WorkCentre PE220
clear.gif ADVANCED BUSINESS COMPUTERS
1523 NW 89TH COURT
MIAMI, FL 33172
Phone: 305-477-2320
Fax: 305-477-3735
Products Serviced: Phaser 4400
Oct 01, 2008 | Xerox Office Equipment & Supplies
Xerox Phaser 6200N Laser Printer Logo
525 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
