Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
I laid the refrigerator on its side to move it, then i found out u were not supposed to do that, I let it sit over night with it unplugged, i've plugged it up this morning and only the freezer is getting cold. What did i do?
  • 10,865 Answers
Hello. Unplug it and let it sit for 72 hours. That will insure that all of the oil has flowed back into the compressor. Joe
Posted on May 02, 2010
My refrigerator wont work after laying it down to move it. What should I do?
I've done that before and there's no hope for it. Once you laid it down the freon got a air pocket in the compressor and it will no longer work. Guy from sears told me that laying them down ruins them.
Feb 20, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
We moved a side by side refrigerator to a different location(from the house to the garage) and the tempterature on the refrigerator side is staying about 48.I have lower the thermostate. Any suggestio
If you moved it, hopefully it was not laid down and remained upright as this can damage compressor. If you were careful and it did not get radically tilted down, then you may want to unplug for a hour or so and see if it clears up. Most often when this happens it is defrosting issue, as in, build up of ice blocking fan operation. Unplugging will melt blockage and help narrow problem down.
Sep 08, 2014 | Refrigerators
Hi my American Fridge Freezer, after moving it and starting it back up, it seems to be going up to its freezer limits digitally also fridge, but when we open it the fridge freezer, ant cold at all. Any...
You may have laid refrigerator down during the move causing oil to migrate to the evaporator. If this has happened leave refrigerator unplugged for about twelve hours so the oil can slowly seep back down to the compressor. Trying to speed this process up will slow you down and may cause the compressor overload to fail. Once the compressor is ready to start cooling you can leave refrigerator plugged in, Thanks Sea Breeze
Feb 21, 2012 | Whirlpool ES5FHAXS Side by Side...
Kenmore side by side - model - 253.54739304. we moved it from one house to another. it was working fine. now won't freeze or cool properly. like it is in defrost mode. compressor was not running...
if while moving it , you laid it on its side, it collected air in the lines, having it unplugged is a good idea, normally 24 hours is enough for the air to settle,, try it again after that time,
Jul 09, 2011 | Refrigerators
Whent it was moved to my new house, it was laid down for awhile,not won't get cold?
Hello. When a fridge is laid on side the fluids in it flow away from necessary areas. Always stand the fridge upright for at least 48 hours before plugging it in. My recommendation is to unplug it and let it sit for 48 hours and then plug it in again. regards, Joe
Feb 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Will not get cold
unplug unit and let sit overnight, then try it again in the morning, if you moved the unit or laid it on its side all the compressor oil needs to settle back down
Nov 04, 2009 | Magic Chef MCBR440 Compact Refrigerator
Moved our GE monogram to new house; was laid on side; now plugged in the motor does not kick on...all lights come on; worked fine before
Oooh -Refrigerators do NOT like laying down.
If you have done this - leave upright - unplugged for at least 4 hours before restarting.
If it has had this - it is possible the compressor may be offcentre inside it's black casing.
Try knocking it fairly hard once or twice, then plugging in again.
If this does not cause life to return, then it needs a serious look at to determine if it is getting power to it, if the control board is doing the right thing, and if the thermostats are set right.
Try resetting the thermostats really low to start with - and see if it wants to try cooling.
Aug 16, 2009 | GE Monogram Side by Side Refrigerator
Freezer is not freezing on Maytag MZD2766GES
When you lay a refrigerator on its side oil from the compressor can seep out into the tubing and cause a restriction in the sealed system. This will cause only a small amount of cooling to occur and needs a licensed technician to fix it.
May 24, 2009 | Maytag MZD2766GES Side by Side...
I have a GE side by side.. When we got home last night I noticed some water on the the floor and the power was on inside the refrigerator but the cooling apparently stopped working. I moved the fridge and...
The defrost timer will turn off the compressor and its cooling fan. At the same time it turns on the defrost heater, and usually leaves the freezer fan running. Defrost can take half an hour, easy. As soon as the defrost thermostat is satisfied, the defrost heater is supposed to turn off, and the compressor may come back on. The defrost timer is about the size of a cell phone, with about five wires going to it in a plug. It has a small dial on it that only goes one way. You can mark it and wait a half hour to see if it moves.
Apr 14, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Cooling
if you have laid the fridge down as you moved it make sure that it sits upright for at least 15 mins before you turn it on again (this alowes the oil in the compressor to level back into the sump)
make sure that everything is running in it - the compressor - any fans and that all airflows are ok.
If all is working then it is a refrigeration problem. low gas, blocked pipes or filter. This will have to be looked at by a refrigeration mechanic
Apr 09, 2008 | Maytag MSD2756GES Side by Side...
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
108 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
