Alpine mrdm1001 alpine amp mrdm1001, turns on but dose not play any sound. i have it running one pionner 1000rms sub it has been working fine for the past 6 months but a friend of mine was playing arround with the settings and now it dose not work. can any one shead some light on this.
    Genius:
  • 1,550 Answers
Probablemente los IC amplificadores de audio esten dañados.
Posted on Apr 04, 2008
SOURCE:
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
When volume turned up subs pop then immediatly produce no sound
u might have to turned your amp so u can play both subs your amp might be to small to run both subs at the same time an u gotta play around with the settings on your cd player so when u blasted your subs it has that nice bass to it not that poping sound.
Apr 04, 2009 | Jl Audio 13W7 Car Subwoofer
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
SUBS NOT PLAYING THROUGH AMP
There is an otion to turn sub output on/off in the "audio menu". Hit " in lower left to turn sub out put on.
Mar 17, 2009 | Xtreme Sound WMS336 CD Player
Ohm wiring
This depends on the ratings of the Amp. Check the docs for your amp. My Alpine will go as low as 2 ohms. The lower you go, the hotter your amp will get, so be aware of that. I actually had to mount a 12v fan next to mine to keep an air flow going over it. The thermal override was tripping.
Mar 04, 2009 | MA Audio HK15X2 Car Subwoofer
I have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
Feb 22, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
SWR-1242D wired at 4ohms
Hi!
Having to much power for a subwoofer is a veeeery good thing, it will provide a lot of control and quality sound to your sub.
But this sub is a dual voice coil at 2 x 4ohm so if you want to hook it up at 4 ohm u need a 2 channel amplifier running mono mode.
i dont recomend that you hook up in 4 ohm, its better to take some time adjusting the levels on the amp and the headunit.
This system has the potential to create a realy good bass sound if u tune it the right way.
Feb 10, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Stopped working.. Blown? or..
how did u wire the speaker ?what is the speaker rated at 2 ohm or 4ohm? thees kicker l7s 15 inch is rated for 1000 rms and 2000 peak the only thing that could of hapend was somthing was touching some were in the wiring or u hade the speaker wired at a load of 1 ohm
May 18, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
 Grubhead
Grubhead
Marvin
Marvin
