Question about Nokia 7370 Cellular Phone
Screen does not swivel
My phone got soaked in water, since then, my screen no longer rotates when the phone swivel and i can no longer answer call by swiveling my phone
    Problem Solver:
  • 11 Answers
Better to service of your phone from a mobile repair shop and never try to dry with hair drier or under sun light or any other type of heat because water dries inside with some white calcium so hurry before water dries inside
Posted on May 02, 2010
Testimonial: "thnx a lot"
Acer b3-20 screen will no longer rotate
It sounds like you have put the rotate lock on.
The button next to the volume is a lock toggle switch.
try that and see if it will rotate.
Nov 16, 2016 | Acer Computers & Internet
Cricket phone screen goes white
You could try and have it repaired but most likely the damage has already been done to the phone so no guarantee it's even fixable. I'd get a new phone maybe one of the water proof one's :)
Sep 10, 2013 | Cricket Wireless Cell Phones
What is a "memory swivel"?
A memory swivel (or return swivel) is a type of bar stool that swivels but then returns to the original position once a person gets up. Most memory swivel stools only rotate 180 degrees.
Jul 24, 2012 | Furniture
One of the front swivel wheel on my bugaboo cameleon is not rotating. Is there a way to remove just the wheel?
You can buy wheels from Bugaboo including a bigger set called snow wheels. The wheel is held on an axel by capped star-lock washers. Prizing them off usually makes them unusable so don't try unless you found replacements. Try soaking the wheel in hot soapy water than a good dose of silicon spray.
Jan 27, 2011 | Bugaboo Cameleon Jogger
Wet Phone with Download screen
it may sound funny but put the phone, battery and nething else that got in a bag of dry rice. it will soak up any water left in the phone. that may fix your problem.
Sep 13, 2009 | Samsung Propel A767 Cell Phone
My samsung SGHJ700 fell in water.iwhat should i do?
The following method can be tried when everything else failed and the phone went through the washing machine, fell in salt water or was in dirty water for a long time etc.
Remove as many parts as possible (Sim card, covers, battery)
1. Soak the phone as soon as possible in distilled water to dissolve any dirt, salt, soap etc ( an ultasonic cleaner will be helpful )
2. Repeat step 1 if necessary ( depends how dirty the water was )
3. Soak the phone in Iso Propyl Alcohol ( a very short time in an ultasonic cleaner will be helpful to dissolve the distilled water in the alcohol )
4. Let the phone dry thoroughly,
5. Cross your fingers and switch it on.
May 17, 2009 | Samsung J700 Cellular Phone
Wolfgang puck swivel waffle baker... power just goes out..
there is a small overheat fuse that blows , no parts made ........ CALL HOME SHOPPING ! tell them what you think of there products ! if everyone did this , you might see longer lasting stuff offered
Nov 29, 2008 | Wolfgang Puck Rotating Waffle Baker -...
My lcd is broken on my sidekick !!!!!!!!!!!!!!!!!
Either buy the entire screen portion off Ebay which would only require you to remove the swivel portion and screen or just the LCD (which would be cheaper but a bit more work to replace, albeit simple). With a small screwdriver, remove the LCD from the phone by unscrewing the back of the screen and replacing LCD. You may still need to remove the entire screen from the base and as the swivel portion is on a coil, be mindful that it doesn't swivel after removal. I usually leave one of the screws in place to keep the screen from swiveling, otherwise, if it uncoils just wind the swivel portion to a moderate tightness and then reattach it to the unit after replacing the LCD.
Dec 03, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Screen
The phone uses two magnets which are located behind the lcd screen to sense when the screen has been swiveled away. There are two sensors which are built into the keyboard which senses the change in magnetic flux. I guess that there are two so that one can determine to which direction the screen was swiveled. So what could happen, is that the keyboard does not make proper contact with the main board within the phone and this can be the cause to the problem. It seems like when too much pressure is applied to the keyboard over time, that the contact pads on the keyboard wears out. So by replacing the keyboard pcb, the problem would likely be solved. One could of course try to fix these pads. One other possibility is that there is something wrong with the magnets behind the lcd. Either missing or misplaced or they are so old that they do not have a sufficient magnetic flux any longer, but I guess that is less likely.
Nov 26, 2007 | Nokia 7373 Cellular Phone
Nokia 7370 Cellular Phone Logo
82 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
