Konica 1212 How do I make double sided copies?
  • Gizmo51 Mar 26, 2008
    Mac, Thanks for the response. I realized the lack of duplex functionality after calling the co. that leased the machine to my parents and they were kind enough to ship me the pages from the manual I needed to assist my father with his problem. (Explaining the vagaries of technology to an 80 year old man that has a computer phobia isn't a task for the faint of heart!
    Regards,
    Gizmo51
  • 168 Answers
Your machine does not have a duplex feature. To make a double sided copy, you must either take the copy after it is made, and place it back in the paper tray or bypass tray.
If you want to see the specification for your machine it is located here in a pdf file.
http://www.madax.pl/pdfy/1212.pdf
Hope this helps.
Good luck.
Mac =)
Posted on Mar 26, 2008
2 Suggested Answers
herminio_hal
  • 210 Answers
SOURCE: konica 1212 - no image on the copy, but copier run properly
this is might be simple solution check how you place you original to Document feeder it should be face up not face down. The transfer/separation corona is not install properly, drum carriage is not install and the locking screw is not screwed in. the last thing my question is did you completely run out of toner? If you did you have run 75 copies before the toner mix in to the developer. there is a shorter way to add toner to the developer but I can not tell you how not unless you are a copier tech.and you should have a extra developer with you in case the developer is over tone. HH
Posted on Aug 10, 2009
How do we reset j12 on konica 1212
power off then depress 2 and 5 and power on
Mar 28, 2016 | Konica Minolta Office Equipment & Supplies
On Konica 1212 what does J11 mean and F54?
J11 means Jammed on 1st paper feed tray & F54 means your key swith is Open(disconnected).
Dec 05, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
How do I copy a double sided document so it stays double sided?
Locate the setting called "Duplex" and look for 2 sided to 2 sided
Apr 26, 2010 | Konica Minolta Office Equipment & Supplies
Instructions for copying double sided
at the main menu of the panel, select "SIMPLEX DUPLEX" option,which is at the right side of the lcd screen, now in "SIMPLEX DUPLEX" option select "DOUBLE SIDED" original to "double sided" copy option and then press the start button...............
Mar 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica 1212 - no image on the copy, but copier run properly
Jun 02, 2009 | Toshiba e-Studio 205 Copier
Double-sided copy output
In print dialogue box there will be a setting for long or short edge binding, associated with duplex printing. Find it and try it. Good Luck.
Apr 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Pls. my Konica 1212
power supply went bad!
try this Reseat CN15 on CB than check the oporation of L1 L2
47 mode 00
hope that help
Oct 11, 2008 | Ricoh Aficio 1013F Copier
204 people viewed this question
k24674
jasbo
jasbo
