Question about Bosch Dishwashers
My Bosch dishwasher sucks! I paid $1,000 for it, it's less than a year old and here's my problem: Everything comes out gritty. Yes, I use Jet Dry, all the correct detergents, my filter is clean, etc. Believe me, I am doing everything right. Also, my glasses and my dishes smell like fish. I'm ready to throw the damn thing out the window. Please help!
Can't solve your problem. Mine cost more and it leaves a film on everything. What a piece of expensive junk!
Posted on Jan 16, 2011
Lots of Dishwasher Issues- I have a Bosch dishwasher that is approximately 1 year old. For the first 6-9 months it cleaned perfect. It would wash everything off the dishes and leave them sparkling clean...
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The residue is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
May 07, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
After washing a load of dishes/pots & pans in the dishwasher, there is a white film & gritty feel on everything. I use Finish dishwasher detergent (powdered) and Jet Dry rinse agent. We do have...
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Mar 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher leaves water at the end of its cycle cleaned filter and the impeller seams free and not blocked
check for over sudzing. dont use a cascade with jet dry in it. use regular dishwashing liquid and fill jet dry compartment. you can even jet dry level by turning the knob in dispenser.
Nov 12, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher never cleans, glasses gritty dirty -- Bosch terrible s
you obviously need to check and make sure that you've cleaned your filter system. it needs to be cleaned every couple of months. and also make sure that your washing fans, the ones that spray water, aren't clogged. they need to be washed out and de-clogged regularly as well... i had this same problem.. but it worked fine once i cleaned the system.
Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Not coming clean
Hi, Are you using Jet Dry Rinse Agent? It is very important to keep the washer supplied with this stuff. Otherwise, glassware will come out with a cloudy film and water spots. If you are using it, perhaps it is not being dispensed by the machine. I am having this trouble now, but my machine is about 10 years old, and has always turned out beautiful glassware unless it ran out of Jet Dry. Now, there seems to be a problem in my machine not dispensing it, and I was searching for a solution when I came across your posting. Baxterdog
Dec 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher problem, Bosch
make sure u have jet dry in unit and put on higher number inside doors
Oct 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Excell Dishwasher
drain pump is running all time. cause is a leak. remove bottom front panel and mop out water or can also tilt at 45deg and water shud run out. machine shud then run but you then hav to find leak
Mar 04, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
405 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
