Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Replace the PTO switch on a John Deere 455
I have diagnosed it down to the pto switch. My daughter and I are attempting to replace the switch. But...I can't figure out how to get the old one off without taking the whole dash board off.
Any tips? It is a pull knob that connects to a black box on the other side of the dash board.
Thanks
Yes to get the out, just reach underneath the dash up to the switch and as as close as you can to the bottom of the dash squeeze together while puuling up. it come out though the top and disconnect the pig tail there
Posted on Jul 10, 2012
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
wireguy212
  • 1627 Answers
SOURCE: Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
Posted on Jun 05, 2010
John Deere x320 PTO switch not getting power. Mower blades will not engage. Replaced PTO clutch and PTO switch. Have checked seat safety switch and RIO switch as well.
Just out of curiosity check your pigtail that plugs into the pot harness. I have ran into a broken wire inside that pigtail before.
Nov 26, 2016 | John Deere Garden
John Deere Z840A Z-Trak mower. Why does engine die when PTO is engaged?
A possible cause is an open seat switch (operator presence). Locate the switch under the seat & unplug the switch from the harness. Place a small jumper wire into the female socket leads to the wire harness. If the PTO engages without engine shutting down, replace the seat switch.
Check to see if the mower deck is plugged or a piece of wood/debris is wedged between the deck and a blade, or some wire/rope is wrapped around a spindle. If the blades don't turn by hand, it'll stall your engine when the electric PTO clutch is energized.
Lastly, a discharged battery will cause an engine shut down if there's not enough reserve when the PTO is engaged. Measure the battery voltage with a meter. If the voltage is below 11.5 volts, you may have to replace the battery.
Oct 23, 2015 | John Deere Garden
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Eletric PTO is not working
The PTO draws a pretty good current, so a weak or loose contact in the switch, or in the connections on the back of the switch, could cause this overheating. But it could also happen if the PTO clutch itself or the wiring to it has a short. If the mower's still under warranty, get the dealer to diagnose and fix it. If not, then I'd measure the resistance of the PTO clutch - should be about 2 ohms - and make sure the wiring to it isn't shorted. If all that is OK, then just replace the PTO switch and any melted connectors and wiring. Good luck!
Jul 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
May 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
John deere 997 z trak pto not working,changed pto switch not help
You may have a defective park brake switch or the pto clutch could need to be adjusted.Does the machine **** down when you try to engage the pto?If so also check the seat switch.To adjust the pto clutch you need a 9/16' wrench and tur all three lock nuts on the clutch a half turn at a time a retry the clutch,keep going until it will stay engaged.
Nov 08, 2009 | Garden
Pto spis all the time on my 1989 john deere 420
Are the blades turning? If they are not, this is normal. The PTO is an electro magnetic clutch that engages when you apply electricity via the PTO switch. When it is disengaged, the bearings and top portion of the clutch will turn because it is coupled to the engine. If the blades ARE turning then you have a bad clutch and will need to repair or replace it
Sep 18, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
779 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
