Question about Sony Handycam DCR-TRV460 Digital Camcorder
Sony dcr-trv361 NTSC compatible with windows 7, how?
  • 32 Answers
SOURCE: HARDWARE COMPATIBILITY
What is the issue?
How are you connecting?
What is the full model number?
Posted on Jan 04, 2008
  • 497 Answers
SOURCE: camcorder SONY DCR-TRV25E, COMPATIBILITY window vista
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System.
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 23, 2009
adnanbhatti
  • 1188 Answers
SOURCE: I need a driver for my Sony Handycam DCR-HC20,
You can find it on the Sony support website. This link takes you there.
Posted on Dec 20, 2009
  • 58 Answers
SOURCE: SONY CAMCORDER DCR-TRV19 DOESN'T WORK ON WINDOWS
The Windows 7 Operating System is not compatible with the USB Streaming feature of the Camcorder.
You can transfer the videos to the Windows 7 Computer using an i.LINK (Firewire) Cable.
You can use the Windows Movie Maker Software to transfer the videos from the Camcorder.
Please follow the steps mentioned in the below link to transfer the videos from the Camcorder to the Computer
Posted on Mar 21, 2010
SOURCE: where can i get free usb driver for windows 7
esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV33
Posted on May 28, 2010
My Sony Handycam DCR-30 is not compatible with my windows 7, what can I do?
I'm assuming you have tried connecting it to your computer with the proper connector. It said something like no drivers for this. Then installing it (with CD or something) anyways and it said not compatible or something.
First, Windows 7 professional and Windows 7 Ultimate have a "Windows XP mode". So if you have one of those versions you could try this. Otherwise skip to the next part. It may work without it but if it doesn't, just use Windows XP mode. Which you can download here. The Microsoft Windows 7 compatability site also says the DCR-HC-30 is compatible.
Second, are you sure it is a "DCR-30?" I did a quick search on the Sony website, and the only thing I could find was a "DCR-HC30." There might be a "DCR-30" but you can try the DCR-HC30 drivers. Which does support Windows 7. It shouldn't mess up your computer installing this driver because it has to be the right hardware, otherwise it wouldn't be in use.
I hope this helps with your problem.
Mar 24, 2011 | Sony Video Cameras
I NEED DRIVERS FOR SONY DIGITAL HANDYCAM DCR-TRV355E FOR WINDOWS 7.
There are no drivers for the Sony Handycam DCR-TRV355E for Windows 7, although it is tested and works in Windows 7 using Windows Movie Maker, and others. Click here for compatibility information.
Here is Sony's DCR-TRV355E Site: http://support.sony-europe.com/dime/camcorders/sd/d8/d8.aspx?site=odw_en_GB&m=DCR-TRV355E
Mar 13, 2011 | Sony Cameras
I have a Handycam dcr hc21 but windows 7 64 do not recognize it, please!!!! any solution for this problem
http://www.microsoft.com/Windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Sony%20Handycam%20DCR-HC21%20MiniDv%202.5LCD%2020X%20Camcorder&v=Sony&uid=DCR-HC21&l=en-US&pf=0&pi=2&c=Cameras%20%26%20Photo&sc=Camcorders&os=64-bit
As you can see at the above link, this camcorder is not compatible with Windows 7 64-bit. Don't worry, you have two options:
1) Switch to Windows 7 32-bit
2) Get a analog to digital converter. Basically, a box that takes the yellow, red, white connections out of your camera (using the cable that came with camera) and converts it to a firewire connection to your computer.
A good converter box: http://www.amazon.com/Hardware-ADVC-55-d-Converter-Ntsc/dp/B000HGVZG0/ref=sr_1_7?s=electronics&ie=UTF8&qid=1299245595&sr=1-7
Hope this helps.
Mar 04, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
Mar 10, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
Sony DCR-HC21E not compatible with windows vista
USB Streaming of the Camcorder is not compatible with with the Vista and the Windows 7 Operating Systems. However, you can transfer the videos to the Computer using i.LINK(firewire) or A/V Cables without using the supplied Software.
Feb 08, 2010 | Sony DCR-HC21E Mini DV Digital Camcorder
My sony digital video camera Model DCR-TRV19E is not compatible for Windows 7. What shall i do?
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Jan 20, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
Camera Sony DCR-TRV145E and software compatibility with Windows 7
j'ai un problème de demarrage de caméra. affiche toujours "system infolithium"
Oct 13, 2009 | Sony Handycam DCR-TRV145 Digital Camcorder
Desperate need for manual
hi,
see if the sony cam manual you need was on this list:
The Sony DCR-TRV480 and DCR-TRV380 Digital8 Manual can be downloaded at: http://www.docs.sony.com/release/DCRTRV480.PDF
The Sony DCR-TRV460 and DCR-TRV361 Digital8 Manual can be downloaded at: http://www.docs.sony.com/release/DCRTRV460.PDF
The Sony DCR-TRV280 Digital8 Manual which also covers the Hi8 CCD-TRV138 and CCD-TRV338 can be downloaded at:
http://www.docs.sony.com/release/DCRTRV280.PDF
The Sony DCR-TRV260 and DCR-TRV265 Digital8 Manual which also covers the Hi8 CCD-TRV128, CCD-TRV228 CCD-TRV328 and CCD-TRV428 can be downloaded at:
http://www.docs.sony.com/release/DCRTRV260.PDF
The Sony DCR-TRV130 Digital8 Manual can be downloaded at: http://www.docs.sony.com/release/DCRTRV130.PDF
The Sony DCR-TRV240, DCR-TRV340, DCR-TRV740 and DCR-TRV840 Digital8 Manual can be downloaded at: http://www.docs.sony.com/release/DCRTRV840.PDF
Jun 02, 2009 | Sony Video Cameras
Sony DCR-TRV361 camera recorder LCD not working
WINDOWS VISTA NO ME RECONOCE EL DRIVER DE LA CAMARA SOñY DCR TRV361 NTSC. NECESITO INSTALAR ESTE DIRVER O DONDE LO CONSIGO?
Sep 11, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
600 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
