Question about NetGear WGR614 Wireless Router
Secure my netgear, please.
Make my netgear secure, please .
    Scholar:
  • 89 Answers
  1. Begin setup of your Netgear Wireless Router by first reading the instructions in the included manual, and following their guidelines for plugging in and initializing the access point. The first few steps in this guide should coincide with the information found in the manual, however we will follow up with important information on how to secure your wireless access point.
  2. After powering up the router, use an ethernet cable to connect your computer to one of the ports on it marked 1 through 4. Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. This will take you to the Netgear Smart Wizard welcome page, click OK to begin the configuration. The router will attempt to detect the type of connection you have and the next message you receive should be Dynamic IP (DHCP) Detected, click Next once you see this.
  3. Next you will enable the wireless capability of your router. In the dropdown box for the region where you are located select United States from the list. On this screen you should also change the Wireless Network Name (SSID) from its default value to something unique so that your Base Station will not be confused with another. Click Next.
  4. You should now see a message confirming that your connection is working and wireless is enabled. However, your are not secured yet. Read the notes and click Done. Then direct your browser to http://www.routerlogin.net to continue the configuration. A window will pop up prompting you for your login and password, enter admin for the username and password for the password, then click OK.
    Hope this helps
Posted on Mar 26, 2008
  • Anonymous Mar 26, 2008
    Here the rest,
    1. Once you have logged in you will see the main configuration page (shown above). Now click on the Wireless Settings at the left of the page. In order to password protect your wireless network select the WEP (Wired Equivalent Privacy) option under the Security Options and then under the Security Encryption (WEP) section that appears, select 128 bit next to Encryption Strength. Choose a password between 6 and 8 characters and type it into the Passphrase box under the Security Encryption (WEP) Key heading. Then click Generate. Finally click Apply. You may also select WPA encryption, however not all network cards support this, so check your documentation first.
    2. Next look for the Advanced section heading on the left side of the page and click on this Wireless Settings section. Disable the SSID broadcast option by unchecking the second box in this section and then click on the Setup Access List button.
    3. On this page (seen below) check the box to Turn Access Control On and click on the Apply button to save this setting.
    4. Now click on the Add button, this will display a Wireless Card Entry heading. This is where you will choose a name and enter a MAC Address, also known as Physical Address, for each computer that you will be using to connect to your wireless network. If you don't know how to get this information follow the steps here. Once you have finished, click the Apply button.
    5. Finally click on the Set Password link on the left of the page under the Maintenance heading. Change the default password for accessing your wireless router setup pages by first typing the old one, password, into the appropriate field and then entering a new one into the New Password field and confirming it. This should be a different password than the one you setup for WEP encryption, but should also be atleast 6 to 8 characters in length. Click the Apply button.
    6. Your Netgear Wireless Router is now secure
Just set up new router. Choise to skip setting up security at that time. HOW DO I GET BACK TO SETTING UP THE SECURITY NOW
Posted on Oct 08, 2008
SOURCE:
What is Netgear44 password for wifi
If the Wireless is Secured, only the person that secured it would know. If you are refering to the default password try Netgear Support: http://support.netgear.com/for_home/default.aspx You ca always reset the Wireless Device to default setting and reconfigure the SSID and the Security Key(password). Take a look at this: http://kb.netgear.com/app/answers/detail/a_id/119/~/configuring-your-netgear-router-for-cable-internet-connection OR This: http://kbserver.netgear.com/pdf/wireless_router_setupmanual.pdf
Mar 19, 2013 | Computers & Internet
Anyone can use my internet how do i set up security code i have netgear wireless 150 wnr1000 router how do i fix this everyone using my enternet
You need to configure your router with wireless encryption.
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 01, 2013 | NetGear Computers & Internet
Loss my netgear wireless security password,
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2012 | NetGear N150 RANGEMAX 150 Wireless Router
How do I secure my Netgear router?
To secure your NetGear Router follow the instructions at the link below:
.../Netgear/WGT624/wireless.htm.. <<
Sep 11, 2011 | NetGear WGT624 Wireless Router
Where do I find the security key for netgear wireless g router WGR614v9-serial number *1W91867RO33ES* as I wish to install a usb wireless adapter on my wife's computer
The encryption key is a security key. The encryption key is configured in the Netgear's wireless setting. To get these settings ie. the SSID and the WPA or WPA2, open a browser and type the Netgear's configuration URL - http://192.168.0.1
Then go to the wireless settings to get this information.
This SSID and WPA or WPA2 encryption key is then used to configure the USB wireless adapter so it can connect to the Netgear.
Oct 30, 2010 | NetGear WGR614 Wireless Router
Pasword protect my router how?
There are two kinds of password protection for your ROUTER;
(1) The Web Interface can be password protected by changing the default password
(2) The Wireless connection password (encryption)
Which one do you want enabled to protect your router?
Jul 27, 2010 | NetGear WGR614 Wireless Router
Can't get access to my secure netgear router
If your computer does not connect to the wireless router, most likely the wireless card has not been configured with the router's wireless settings ie. SSID, encryption etc.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
Jan 29, 2010 | NetGear WGR614 Wireless Router
DONT KNOW WHAT MY SECURITY KEY IS CAN I RESET? IT
Do you mean the encryption key?
If so you can reset the Netgear back to the default settings and setup a new encryption key.
To RESET the router, press the pinhole RESET button at the back of the router for approx. 10 secs until the LEDs flash.
For instrustions on how to secure and configure the Netgear wireless router and the wireless card in the computer/laptop please click on this link :-
The Netgear configuration URL http://192.168.0.1
Default login = admin
Default PW = password
Should you need further help, please leave me a comment.
Dec 25, 2009 | NetGear WGR614 Wireless Router
Need to protect my wireless network!
you must logon to the NetGear wireless router and setup wireless security. choose a security type usually WEP, type a key phrase or passphrase and voila, you will have to re-connect on your clients by entering the password when you get prompted for it.
Jun 03, 2009 | NetGear WGXB102 Wireless Range Extender...
NETGEAR WGR614v7 Network Security key
Hi, you need to connect to the routers admin pages to configure the wireless settings and security. Check out this page:-
http://kbserver.netgear.com/kb_web_files/n101676.asp
When you get to step 6, click the WPA-PSK security setting and it will give you a box to type in a password of your choice, make it memorable but difficult to guess, so a mixture of numbers and letters. I think its a min of 8 characters.
Hope this helps..
Jan 25, 2009 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
117 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
