Question about Dell Inspiron 6000 Notebook
My Dell Inspiron 6000 won't boot up. It keeps
My Dell Inspiron 6000 laptop won't boot up. It keeps reverting back to the screen where you can boot in safe mode or normal mode, so it keeps attempting to restart unsuccessfully.
In that safe mode/normal screen it says to reinsert the windows disk and select repair, but the system does not acknowledge that there is a disk in the drive. It won't boot from the disk. In the DST short test, I received the error code 1000-1046. Does this mean the hard drive has failed or is dead?
Any advice would be appreciated, before I invest in a new hard drive.
Thank you.
  • EvelynJK May 02, 2010
    Thanks very much for the advice. I was able to go in and change the boot order to boot from cd/dvd drive first. It has recognozed the disk and started the installation process, but it is a Vista upgrade and won't install from boot. I was able to get to the repair area and it is analyzing the system right how. I'm hoping it was a Windows crash and not the hard drive... I can install XP from boot and upgrade to Vista from there if need be.
    I'll post the results when I know more. I'll lose a bunch of music and videos in the process, but luckily my laptop has become a recreational computer for me since I got my desktop computer last year.
    Thanks again!
    Well, it's not the hard drive. XP installed and the computer booted up fine. Now I can install the Vista upgrade and all of my programs, and my dell drives (wireless) and I'll be back in business.
    Thanks again for your help. Changing the boot order saved me from buying a new hard drive!
    President:
  • 1,149 Answers
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
Posted on May 02, 2010
Testimonial: "Great advise. Thank you!!"
I have s dell inspiron 6000 that is stuck in safe mode
This happens when set you PC on Safeboot Option.
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Dec 16, 2010 | Computers & Internet
My Dell Inspiron 6000 (which I think I bought in
Have you tried this:
1. After removing the battery
2. Press and hold the power button for at least 10 sec.
3. Put back the battery
4. Turn it on
if this doesnt work, there could be a problem with your operating system. Try accessing safe mode if you can login .TAP F8 continously on the dell logo screen, and it will open advance boot options. (Just select safe mode) If safe mode boots properly try running system restore to restore it back to the previous date where your computer is still booting to windows. Hope this helps
Dec 08, 2009 | Dell Inspiron 6000 Notebook
I turn on my dell and it boots up then kicks back to the dell screen over and over
when your dell is start keep hitting the f8 key then boot into safe mode.do a virus scan.if clean then move down to last knowin good config.if that dont work you may have to reformat ur computer or try repair.
Dec 07, 2009 | Dell Inspiron 6000 Notebook
My dell inspiron 1525 continuously keeps locking up. The screen just freezes up. I am unable to bring up task manager or hit escape. The only thing I can do is shut the power down / bring back up. This is...
Try this steps:
Turn off your laptop.
Power own your laptop then press release the F8 key until this option will popup.
Select Safe Mode.
Wait until Windows succesfully boots up using safe mode.
If you can succesfully log-on on your Safe Mode.
Press Windows Key + R
The run window pops up type MSCONFIG
Click Start Up as show below
Uncheck all check Items and click OK
Reboot your laptop and boot windows in normal mode...
Hope this helps...
Oct 21, 2009 | Dell Inspiron 1525 Laptop
Black Screen Dell 600 Laptop
The display drivers maybe corrupt.
Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the Dell support website.
If it still won't display in normal mode please post back.
Good luck.
Sep 17, 2009 | Dell Inspiron 6000 Notebook
Keeps logging off
If you cannot log into windows in either the normal or safe mode, your repair options are limited.
You can try the following:
  1. Run diagnostics on the hard drive, see if it fails, if the drive fails diags, replace it.
  2. If the drive passes diags, then try booting to recovery console (Boot to XP CD, R at first prompt. Try running the chkdsk /r command.
  3. If no change, try a repair reinstall of windows.
Jul 31, 2009 | Dell Latitude D600 Notebook
Stuck on "loading your personal settings..." screen.
try booting to the SAFE MODE (F8 at boot) and see if you can log in to the ADMIN account from the safe mode. If you can, then create a new user profile, then reboot to normal mode and try booting to the NEW profile. If that works, then the old profile is likely corrupt
Jan 19, 2009 | Dell Inspiron 6000 Notebook
My wife's Dell Inspiron 6000 has developed a problem when booting up. After the WindowsXP screen, the screen goes black. The Windows sound is heard, so I presume the machine is running OK, but there is no...
Your PC is not completing bootup. It's not the display, it's Windows.
Try booting to Safe Mode (F8) and running System Restore to a time before the issue cropped up. That should get the PC running again.
Dec 29, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 6000 Notebook Logo
1,215 people viewed this question
Alun Cox
